edge juice no start?
Old Nov 13, 2012 | 07:29 AM
brapom's Avatar
brapom
drove to work this am and after idling for 5 min I shut key off, motor shut down and the juice shut off then came back on. Tryed to restart truck and just cranked and no glow plug light lit. unplugged the module and reconnected then truck started up and when shut down juice now off. Bad module? thanks 07 f350 drw
Old Nov 13, 2012 | 08:57 AM
dlibson's Avatar
dlibson
Could be, or could just have been a fluke. Plug it back in and see...
Be prepared to be told about your junk edge from many too...
Old Nov 13, 2012 | 02:48 PM
04problemchild's Avatar
04problemchild
Whats wrong with the edge juice? I had a similar problem. Plugged in juice and no start
turned out to be ficm but now am leery of trying it again as I purchased it used. Thanks for the post on the air loss at turbo to, just replaced oil cooler and welded up egr cooler to make a poor mans delete kit and am having same issue.
Old Nov 13, 2012 | 03:15 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Edge Juice takes out the AUTO tranny
Old Nov 13, 2012 | 07:25 PM
dlibson's Avatar
dlibson
Except the auto trannys in my two trucks that have had an edge tuner for a combined 150k...
Tuners don't take out trannys. Drivers of tuned vehicles do...
Old Nov 13, 2012 | 07:32 PM
04problemchild
I can relate to that. Have you ever heard of a tuner shorting out? There plug and play, right?
Old Nov 13, 2012 | 07:36 PM
dlibson's Avatar
dlibson
Well some plug into the obd port and download.
Some are plug and play. Myself, I cannot stand the BS of waiting 5 minutes to download a tune. That's why I run an Edge, shift on the fly tuning.
But any tuner can short out. It's an electronic device.
As for your Edge, I bought mine used. Been fine. Never missed a beat. If your ficm was bad, it likely was not from the Edge...
Old Nov 13, 2012 | 07:41 PM
04problemchild
thanks, mine plugs into the pcm as well. how long did you have to wait for the computers to start talking to each other before it started?
Old Nov 13, 2012 | 07:44 PM
dlibson's Avatar
dlibson
You mean the Edge and PCM? Pretty much right away...
savage250
6.7L Power Stroke Diesel
22
Mar 17, 2013 08:57 AM
guntruck
Apr 1, 2012 11:06 AM
Special Ed
Dec 2, 2011 09:55 PM
wrdabney
Nov 8, 2009 09:42 PM
clemsonsuperduty
Feb 17, 2005 07:31 PM
