coolent and surge
Old Oct 20, 2012 | 10:36 PM
04badford's Avatar
04badford
coolent and surge
Hey guys today I worked on my 04 6.0 when i pulled the degus bottle red coolent came out I dont use anything but preimum gold I had jiffy lube do the last oil change and had them put in the ford oem always oil filter with rotella 15-40 took the truck back today they said and showed me they dont use anything but gold but they could pull the recorded video to see. what would cause this ? we checked the tranny dip stick and it was red not milky same with the oil dip. Benny also I cleaned the EBP and tube some debre and black soot but not clooged went to ford today to find out the ICP is on the rocker cover so this truck is the later 04, tomarrows job is the MAP sensor and tubeing and less bleeding to the hands LOL. jiffy did top every thing off
Old Oct 20, 2012 | 10:39 PM
BLADE35's Avatar
BLADE35
you need a New Radiator the Trans Cooler in the Radiator is Leaking Trans Fluid its mixing the fluids stop driving it
Old Oct 20, 2012 | 10:41 PM
BLADE35's Avatar
BLADE35
IIRC the MAP sensor was the One with the BAD Reading
Old Oct 20, 2012 | 10:43 PM
04badford's Avatar
04badford
also coolent smells like coolent not tranny or diesal fuel and its not oily feeling. going for the flush monday.First thing
Old Oct 20, 2012 | 10:48 PM
04badford's Avatar
04badford
OK Thanks Benny , I'll look in the tech folders for the process , anything else while Im in there CACboot ? I"M was to slow to type to ur 2 posts
Old Oct 20, 2012 | 10:53 PM
BLADE35's Avatar
BLADE35
I hope your going to Install a New Radiator first or the flush will be a Waiste of time
You have a Internal Trans cooler in the radiator Just follow the lines from the passengerside External trans filter to the front of truck you will see Trans lines goes into the Radiator
I think Mark K. Said this was to help heat the Trans Fluid why it goes into the radiator
Old Oct 20, 2012 | 11:03 PM
04badford's Avatar
04badford
OH defently, looking in tech but dident see any thing on the severity of skin loss in changeing the radiator ha ha, doin the map tomarrow, but I shouldent start or shouldent drive any way the CHEVY will get me to work. OLD BLUE has 3650000and some change on it and still runnig great..
Old Oct 20, 2012 | 11:14 PM
BLADE35's Avatar
BLADE35
I know to some thats a Bad Word
I have owned a Few Chev cars they been great
I dont care the maker I just want dependable ride
I have had 1 Dodge Dakota it was the Worst I traded for my 6.0L
Old Oct 20, 2012 | 11:16 PM
BLADE35's Avatar
BLADE35
I think BPD has a good radiator IIRC NO Plastic maybe
Old Oct 20, 2012 | 11:53 PM
04badford's Avatar
04badford
I wish I can say I'm sorry but 1992 silverodo with ONLY 1 recall come on ford , bpd radiator should I be looking for alum exterior and int core or is ext all plastic now days, with the chem flush the 60s have to have dont want anything getting eatin up. in nor cal 1800 radiator the 92 has had one in for 5 years now. also looked up Champion but didnt see 04 diesal on there web
Old Oct 21, 2012 | 01:17 AM
BLADE35's Avatar
BLADE35
I think BPD sell all Aluminum radiator
The thing with Diesels is they all Got to good reliability point then they all had to get Emmisions compliant something the Gassers had to go threw Along time ago Im shure they had there Issues to
When it rains it pours LOL
Old Oct 21, 2012 | 01:29 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
This what the trans cooler looks like inside the bottom plastic tank.
If the tranny cooler is compromised it has nothing to do with the plastic.
If the plastic cracks then coolant leaks out.
Josh
Old Oct 21, 2012 | 02:22 AM
BLADE35's Avatar
BLADE35
Josh Im Just saying since he has to get a New Radiator might as well get an ALL Aluminum for Durability
Thats a Given coolant would leak if plastic tank cracked
Them plastic tanks is one problem I have had on my chev berretta
Just thinking Longevity
Old Oct 21, 2012 | 08:15 AM
bismic's Avatar
bismic
I believe Mishimoto sells a decent radiator also. It is also all aluminum - for those who are interested.....
I don't think there have been too many issues w/ OEM radiators, but haven't seen anything bad said about the two mentioned aftermarket ones either.
Old Oct 21, 2012 | 10:45 AM
Bullitt390's Avatar
Bullitt390
Ahhh gotcha.
Mishimoto as mentioned makes an all aluminum radiator. OR quick service companies like Radiator Express also make them.
Ebay has some too, but might seem sketchy to order from there.
Josh
