Wtf is all this ****
Old Nov 11, 2012 | 09:28 PM
Germy's Avatar
Germy
I opened the hood to my first f250 1978. I guess this is about when emissions started. There are tubes everywhere. Can I just go hei and ditch all the ignition? Run vacuum to brake booster, egr and dizzy, throw everything else away. How does that sound
Old Nov 11, 2012 | 09:42 PM
HIO Silver's Avatar
HIO Silver
Have you researched what needs to be done in your state if subject to emissions?
If not subject, then consider boxing up all the check valves/housings/air pump, etc.. and selling 'em to a fellow FTE'er. Emissions parts are becoming hard to come by so help out by perhaps making them available to keep another Dentside on the road.
Your cooperation is appreciated.
Old Nov 11, 2012 | 09:45 PM
pro3qtr's Avatar
pro3qtr
Um really, emissions started WAY before this truck and NOT all had it.
My 78 F250 was leaded and cat free.
Old Nov 11, 2012 | 11:19 PM
kobaltblue's Avatar
kobaltblue
Find a BIG thing with a circle on top and its 32" in height say about some have a flat thing that sits on top, And toss it all in! Unless you live in the communist state of California your on your own.
Old Nov 12, 2012 | 12:20 AM
nine inch rear's Avatar
nine inch rear
As long as you dont move to California with the truck, youll be fine ditching the stuff.
Old Nov 12, 2012 | 12:50 AM
jgavac's Avatar
jgavac
Depends on local laws. In my county, they don't smog people at all. Go 30 minutes to a new county and you have to pass smog.
Old Nov 12, 2012 | 03:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
CA smog tests 1976 and newer vehicles, but some other states smog test earlier than 1976 vehicles.
PCV introduced 1961 / T/ E (Thermactor Emission - smog pump): 1966 / NOX: 1967 / Evaporative Emission: 1970 / EGR: 1973.
Cats: 1976 F100; 1977 F150/250/350's, but not all states required cats 1976/77, nor PCV in 1961, T/E in 1966, Evap/Em in 1970.
Old Nov 12, 2012 | 12:52 PM
KIKKUP's Avatar
KIKKUP
I got a 78' but it's been transplanted with a 429 by the PO, so I'm sure it's missing some factory stuff but I don't really follow why anybody wants to purposefully 'ditch' the factory emission controls? Maybe the better way of asking is what is gained by stripping them?
Old Nov 12, 2012 | 01:04 PM
jgavac's Avatar
jgavac
"Opens up" the engine a bit. By removing the smog control, you are eliminating gas (not fuel) recycling, so your air/fuel charge is cleaner. Removing the cat opens up the flow on the exhaust slightly.
The later smogged engines are choked down by the equipment, as well as a retarded timing set.
I say if you don't need to pass smog, don't leave it on. There's just more parts and hoses then you need. The only thing I don't know about (and maybe someone can answer this), is if you remove the smog crap, do you have to plug the holes in the back of the heads?
Jameson
Old Nov 12, 2012 | 01:42 PM
Germy's Avatar
Germy
All in garbage. Soon all states will model California. Our recent election will ensure it.
jecsd1
Oct 25, 2006 01:24 PM
Awsum77
28
Sep 11, 2005 08:11 PM
snagmaster86
Jan 26, 2005 10:53 AM
86bigredF250
Exhaust Systems
Jan 1, 2005 01:13 AM
zeppeh
Jan 15, 2004 08:15 PM
