1986 owners help please!
Old Nov 11, 2012 | 12:23 PM
bashby's Avatar
bashby
This question would probably be better answered in the 80-86 section, since it's not diesel related, so if you don't get an answer here you may want to try there. I'm ASSuming you have vacuum assist brakes and they are working, indicating your vacuum pump is OK.
There should be a vacuum line going from the engine compartment through the firewall, toward the passenger side of the engine comp. Make sure it is hooked up and has vacuum with the engine running. If it does, tear into the dash to the heater controls and see if you have vacuum there.
Old Nov 11, 2012 | 12:30 PM
Eallend7's Avatar
Eallend7
I'm pretty sure that is the vacuum line that i'm talking about, which is not hooked up to anything, which i'm baffled as to where it is supposed to go, plastic ball is what i've continued to hear.
Old Nov 15, 2012 | 03:21 AM
Ford F834's Avatar
Ford F834
Mobile Photobucket
There. Hope that works. Been in the middle of a move, and iPhone is surprisingly much more difficult than a computer to share photos etc. Anyway, if the link works you will see that the vacuum ball on the passenger fender has a hose that runs to a "T", with a slender hose going into the top of the heater box and a thicker hose going to the multi-port manifold on the fire wall. My truck also has the coffee can on the driver side fender, and its hose attaches to the same multi-port manifold. Hope this helps. My truck is an 86 F350 XL.
77_150
Jan 18, 2011 09:28 AM
RomeoAlphaYankee
May 27, 2003 07:28 PM
RomeoAlphaYankee
1978 - 1996 Big Bronco
May 25, 2003 07:33 PM
kohlerjd110
Apr 30, 2003 06:07 PM
