1986 owners help please!
Old Nov 10, 2012 | 09:11 AM
Eallend7's Avatar
Eallend7
I would really like to get my dash put back together here soon, my problem is my air doesn't blow out of the face vents, everything seems to be in place except for an A/C vacuum reservoir as it is called on LMC truck. It's seeming more and more like 86 was a ******* year for these trucks because 87 is completely different with a climatiser dryer and all sorts of things changed. Does anyone have an 86 with a picture of the plastic ball in the engine bay and where it is hooked up to??? Also does Number 21 in this diagram look like what i would need??? Any help please i can't find any at the junkyard even close so yall are my last resort!
Truck Parts and Truck Accessories
Here is the link to that diagram hopefully. If not it's page 52
Old Nov 10, 2012 | 10:21 AM
86f250XLT-4x4's Avatar
86f250XLT-4x4
couldn't tell you i haven't had my dash apart yet... when i do take my dash apart i am switching to the 89 vent hook up system... seems to work alot better... sorry couldn't be any help... honestly my vent selectors don't work at all
Old Nov 10, 2012 | 12:23 PM
Eallend7's Avatar
Eallend7
The plastic ball "reservoir" i'm talking about is in the engine bay, passenger side, in the corner closer to the firewall if i'm not mistaken, does yours have this??
Old Nov 10, 2012 | 12:28 PM
86f250XLT-4x4
yes it does... never knew what that thing is... idk if i took it out or not... maybe mine don't work cuz i don't think its hooked up anymore if its still under the hood
Old Nov 10, 2012 | 12:33 PM
Eallend7's Avatar
Eallend7
if you ever get under there to check let me know if it's hooked up or not, or take a picture! hah, i know our models are supposed to have them and i am almost completely sure that's why my vents dont blow.
Old Nov 10, 2012 | 12:38 PM
86f250XLT-4x4
my stuff don't move at all... i will try to post pictures later... or if you would like pics sooner pm me your phone number and when i get to my truck in a little bit... i will take some pics and send them to you... or tell you that its not hooked up
Old Nov 10, 2012 | 08:16 PM
Ford F834's Avatar
Ford F834
Vent selectors are not working on my truck either, but it does have the ball and iirc it's still hooked up. I'll check it out when I get home from work in the morning. My problem is no heat on the feet, and very little on the windshield
Old Nov 10, 2012 | 09:10 PM
vfelix702's Avatar
vfelix702
The vac canister hold vacuum to operate the blend doors for heating and cooling aswell as the cruise control... I have the coffee can stlye in my truck
Old Nov 10, 2012 | 09:11 PM
Eallend7's Avatar
Eallend7
From what i've been told that has to do with your vent selector door thing, on your passenger side floorboard find the vent that the air comes out of for the feet, should be easy to see, if your hands are small enough, mine were, reach a few fingers up inside and feel around while you move the selector switch, if something is blocking it you'll know, other than that it may be something with the cables all jacked up. Where does your ball hook to????
EDIT!: Can anyone tell me what the daggone ball or canister hooks up to?! haha, i have heard the can is used for the trucks with cruise control, so i jacked one of those from the junkyard thinking that would work the same way, if it will i'll just use that but all these answers are conflicting hah, the coffee can only has one nipple for a tube on it.
Old Nov 10, 2012 | 09:17 PM
vfelix702's Avatar
vfelix702
Ill take pictures of the actuators that operate the doors and directionals of the vents and the coffee can... each actuator has a vacuum line hooked up to it.
Old Nov 10, 2012 | 09:33 PM
Eallend7's Avatar
Eallend7
Okay thanks, it's just confusing trying to mozy around the jy looking for my year truck and seeing what's supposed to be where, it seem severything was moved around after '86. My truck has a hose that goes through the firewall that isn't attatched to anything, and runs up into the face vents. I'm sure that's supposed to be attatched to either that plastic ball or coffee can, im thinking the ball, but i have been told there is another hose that runs from the ball somewhere else. On my firewall about the center of it there is a plastic piece with hoses going into it and or with rubber caps over the nipples, they are all plugged except maybe 1 or 2 i can't recall, i would figure if there was something missing it wuldn't be capped like it came frmo the factory or something? idk? just lemmee know! haha
Old Nov 10, 2012 | 10:44 PM
vfelix702's Avatar
vfelix702
Here are some pics ill take more in the morning when we can see more is there colors your looking for and in question?
Old Nov 11, 2012 | 07:48 AM
Eallend7's Avatar
Eallend7
my truck doesn't have any colored hoses, is that your 90 i'm assuming? That's what i was saying about everthing changing hah, because your's has so much extra stuff in there that mine doesn't have at all
Old Nov 11, 2012 | 11:31 AM
bashby's Avatar
bashby
In 86 the AC trucks had vacuum operated system, non ac were cable operated. All the reservoir does is keep the vents from changing positions under WOT when the vacuum drops off. It will work without it as long as you have no leaks. Make sure you have vaccum to the selector switch.
Old Nov 11, 2012 | 12:17 PM
Eallend7's Avatar
Eallend7
how do i check for that?
Also i'm still unsure as to how the FACE vents would even get air considering there's a hose clearly going to those vents hanging through the firewall not attached to anything. Is there just something that is in the cab that blows air up to the vents? I don't see how this hose has nothing to do with it.
