putting in a/c
Old Apr 27, 2003 | 06:16 PM
kohlerjd110's Avatar
kohlerjd110
Question putting in a/c
Can i put aircondition in a 82 f-250 custom that came out of a 86 f-250 xlt. I have everything out of the 86. all the vents and parts.Even the dash controls the only problem i can see will be that the 86 has vacume controled switches and the 82 has cables.Can i use the cables or do i have to convert to vacume.Is it hard to convert to vacume?Can i use the vents that are under the dash now or do i have to use the ones out of the 86.How much needs to be changed.
Old Apr 27, 2003 | 09:26 PM
steve83's Avatar
steve83
putting in a/c
It should work fine if you use ALL the '86 parts. Get the whole duct system that's attached to the firewall; both from the engine compartment and from behind the dash.
Old Apr 28, 2003 | 09:57 AM
brown 4x4's Avatar
brown 4x4
putting in a/c
You will have to cut a bigger hole in the firewall as the heater-only trucks have a smaller opening. That should be the hardest part if you have everything else you need.
Old Apr 28, 2003 | 11:39 AM
kohlerjd110
putting in a/c
how do i hook up the vacume lines?
Old Apr 28, 2003 | 02:16 PM
steve83's Avatar
steve83
putting in a/c
If you use the '86 system, hook the vacuum lines up just the way they come off of it.
Old Apr 29, 2003 | 12:19 PM
kohlerjd110
putting in a/c
Where do i hook them to .
Old Apr 29, 2003 | 04:48 PM
Franklin2's Avatar
Franklin2
putting in a/c
I have never done this swap before, but from looking at the breakdown of the system, it seems like all the vacuum lines are self contained in the system, except for one source line that comes from a tree mounted on the firewall(engine vacuum source) In other words, all the vacuum lines will go from the new a/c control, to the new air door actuators that you robbed from the other truck. If you don't know how all these hook up, then good luck.
here's a picture
http://www2.autozone.com/images/cds/...3d800a82d7.gif
Old Apr 30, 2003 | 06:07 PM
kohlerjd110
putting in a/c
Thank you for the help! i'm going to get going on it.
Shovelhead 93
2004 - 2008 F150
Jun 7, 2009 03:32 PM
kohlerjd110
May 20, 2003 09:32 PM
mossberg
Aug 16, 2001 01:16 PM
gckk
Jun 21, 2000 02:41 PM
