Sponsored by: Auxito
No Heat..
Old Nov 9, 2012 | 02:15 PM
speedracer2012's Avatar
speedracer2012
No Heat..
Just discovered I don't have any heat in the cabin. I have deduced that it has to be either the blend door, motor that moves it or the temperature control. I have removed the components and found the blend door is o.k. it moves freely and the bottom is still there (are some cracks appearing so will glue or tyrap to try and save). I applied voltage to the controller and nothing happened when I rotated the temp ****. NOW the rub. How do I determine if it is the temperature controller in the dash or the controller motor?? Anyone have a checkout procedure for this? THANks for any help provided.
Old Nov 9, 2012 | 05:29 PM
steve(ill)'s Avatar
steve(ill)
measure voltage at the motor with a volt meter ? Or put jumpers to the motor and see if it runs ?
Old Nov 9, 2012 | 05:40 PM
speedracer2012
Can you be a tad more specific as to the pins or color wires that I can measure the voltage at or the pins on the module that I can apply 12 volts to? As I remember there are 6 wires in the bundle.. Thankis..
Old Nov 11, 2012 | 06:04 AM
ranger7ltr's Avatar
ranger7ltr
Make sure fuse # 5 is good then follow the below procedure...
<table rules="groups" border="1" cellpadding="3" cellspacing="0" width="96%"><tbody> <tr> <td colspan="2">D4 CHECK THE VOLTAGE TO THE A/C ELECTRONIC BLEND DOOR ACTUATOR MOTOR </td></tr></tbody> <tbody> <tr valign="top"> <td valign="top">
</td> <td valign="top">
</td></tr> <tr valign="top"> <td valign="top">
A/C Electronic Blend Door Actuator Motor C229
</td> <td valign="top"> Measure the voltage between the A/C electronic blend door actuator motor C229-7, Circuit 295 (LB/PK), and ground.
</td></tr> <tr valign="top"> <td>
</td> <td>
  • Is the voltage greater than 10 volts?
Yes GO to D5 .
No REPAIR Circuit 295 (LB/PK). TEST the system for normal operation.
</td></tr> </tbody><tbody> <tr> <td colspan="2"> D5 CHECK CIRCUITS 436 (R/LG), 437 (Y/LG) AND 438 (R/W) </td></tr></tbody> <tbody> <tr valign="top"> <td valign="top">
Blend Door Actuator Control C220
</td> <td valign="top"> Measure the resistance between the following pins:
    </td> <td>
    • Are the resistances less than 5 ohms?
    Yes GO to D6 .
    No REPAIR the circuit(s) in question. TEST the system for normal operation.
    </td></tr> </tbody><tbody> <tr> <td colspan="2"> D6 CHECK THE A/C CONTROL POTENTIOMETER </td></tr></tbody> <tbody> <tr valign="top"> <td valign="top">
    </td> <td valign="top"> Measure the resistance between the blend door actuator control terminal 2 Circuit 437 (Y/LG) and terminal 3 Circuit 436 (R/LG).
    </td> <td>
    • Is the blend door actuator control at full WARM greater than 3,000 ohms and at full COOL less than 300 ohms? Is there a linear variation in the resistance between COOL and WARM?
    Yes GO to D7 .
    No REPLACE the blend door actuator control. TEST the system for normal operation.
    </td></tr> </tbody><tbody> <tr> <td colspan="2"> D7 CHECK CIRCUIT 57 (BK) </td></tr></tbody> <tbody> <tr valign="top"> <td valign="top">
    </td> <td valign="top"> Measure the resistance between the A/C electronic blend door actuator motor C229-8, Circuit 57 (BK), and ground.
    </td> <td>
    • Is the resistance less than 5 ohms?
    Yes REPLACE the A/C electronic blend door actuator motor. TEST the system for normal operation.
    No REPAIR Circuit 57 (BK). TEST the system for normal operation.
    </td></tr></tbody></table>
    Old Nov 11, 2012 | 06:10 AM
    ranger7ltr's Avatar
    ranger7ltr
    This is what I did for my no-heat issue..
    I checked the actuator motor with my scope and heard no sound and saw no movement after I disconnected the plug and re-connected the plug... I then unplugged the old motor and plugged in the new motor I bought and then with the key on I turned the temp **** and watched the motor shaft rotate from side to side...
    I then tried the old motor one more time and the motor actually turned from full cold to full hot and STAYED THERE... So I pulled the old motor, lubed the shaft with a dab of grease, and installed the new motor and put the screws in it...
    I bought my motor from Rockauto for MUCH LESS than Ford wanted for it...I think I found it for 33 plus shipping...
    Old Nov 11, 2012 | 05:41 PM
    speedracer2012
    THANKS to all that responded. After following the enclosed troubleshooting sheets it appeared to be the motor. I opened it up and found the circuit board was black and the back side destroyed. The motor was also badly rusted. Soo, it appears the flap door motor was indeed the culprit. Will get one tomorrow and hopefully can move on. THanks again..
    GulfcoastSD
    Jul 3, 2018 07:29 PM
    srkr
    Nov 17, 2017 11:23 PM
    Zazoos
    Nov 6, 2016 03:43 PM
    ExploringNH
    Aug 15, 2014 09:36 PM
    Mcnewt
    34
    Jun 2, 2013 07:41 PM
