overhead console
Old May 21, 2003 | 01:04 PM
Copperhead's Avatar
Copperhead
overhead console
I have a 1999 ford expedition eddie bauer. When I got the truck it was filled up and it read 428 miles to empty, now when I fill it up it says 386 miles till empty. Which is right?
Old May 21, 2003 | 05:37 PM
Mud Doc's Avatar
Mud Doc
overhead console
Probably both. I think the mileage to empty shown just after filling the tank is based on the average mpg on the last tank, until you begin driving and a different mpg is established. There are times when I have been towing my trailer, store it, go fill up, and the miles to empty increases for several miles even as I am using fuel. In other words, if your were using gas at 10 mpg on the previous tank, fill it up, you should read 280-290 miles to empty. If you start using the next tank at 12 mpg, it will adjust before long to account for the better mileage. Always reset the average mpg at each fillup, or it will average the previous mpgs in.
Old May 22, 2003 | 10:27 AM
ms6073's Avatar
ms6073
overhead console
Not too long ago, somone posted that when filling up, you should employ the 3-click method! That is, while fueling, if using a nozzle with a trigger lock, let the tank fill with lock engaged and after it "clicks" the first time, carefully continue manually filling (dont use trigger lock) until it clicks 2-3 more times. If you dont mind spending slightly more at the pump, you can usually get another 2-3 gallons in the tank with this method.
Michael
Old May 23, 2003 | 12:59 AM
BigMattXXL's Avatar
BigMattXXL
overhead console
Michael
You have to be careful though - apparently the Ford tanks are designed with a little dome in the top to allow for expansion/vapors. If you overfill the tank, it'll saturate the little emissions vapor canister thingamajig. I don't really know what it does, but apparently saturating it is a bad thing. I personally pump the gas full on until 1 click, and then full on to clicks 2 and 3. Then I squeeze a bit more in to round it up
XXL
dirthawg
Feb 15, 2017 08:16 PM
motofreek77
Jan 26, 2017 07:15 PM
Coolio2000
Nov 11, 2016 10:20 PM
vellingapa
Dec 28, 2013 04:26 AM
Toreador_Diesel
Oct 20, 2003 09:32 PM
