Temperature controls
Old May 12, 2003 | 08:00 AM
MitchPeters's Avatar
MitchPeters
Unhappy Temperature controls
My **** that controls the hot and cold for the heater does not seem to catch all of the time. I have to turn it back and forth a couple of times to go from cool air to hot air and back. Are they cable controls or electronic?
Old May 13, 2003 | 07:27 PM
sharilynn72's Avatar
sharilynn72
Funny you just posted that, cuz I just found I'm having the same exact problem & was gonna post a question!
Old May 14, 2003 | 08:25 AM
RJExp.'s Avatar
RJExp.
Had the same problem. Pull the temp control **** off and check to see if the female end of the **** is broken. Mine ended up being broken and all I needed to do was replace the ****. I originally thought the switch was bad and started to replace the switch. The switch is electitric and is mounted to the back of the face plate. **** at the Ford Stealer was $7 and switch was $15.
Old May 15, 2003 | 08:16 AM
MitchPeters
Thanks. My **** is broken. I will get a new one and try it.
Old May 23, 2003 | 07:29 AM
MitchPeters
The **** only cost $8. Wow a Ford part that is not expensive.
