Brake problems..
Old Nov 7, 2012 | 01:16 PM
rockiestwins's Avatar
rockiestwins
Question Brake problems..
(1997 Ford F350 crewcab powerstroke)So I am wondering if anyone has any ideas on where to start to look for the problem. My brakes will lock up in the back and make a skidding nose. The back end will also jump. But this does not happen all the time. It seems like once the truck warms up and you have been driving it for awhile it will do it.
Old Nov 7, 2012 | 07:06 PM
Red97350's Avatar
Red97350
Welcome to FTE! I'm not sure what to say about your brake problem, but this will give you a bump. On second thought, have you pulled the drums off the rear? I would start there and make sure everything is where it is supposed to be. Hope this helps.
Red
Old Nov 7, 2012 | 07:16 PM
rockiestwins
Well it only happens when you apply the brakes. Also this truck had sat for like a year.
Old Nov 7, 2012 | 07:26 PM
ReBilld's Avatar
ReBilld
Pull the rear drums and clean them inside. Check the brake shoes and replace them if they need it. Clean everything up and check to make sure the wheel cylinders aren't leaking. My truck will do this when I take off in the mornings sometimes, but I know I need to replace the rear brakes.
Old Nov 7, 2012 | 07:46 PM
Red97350's Avatar
Red97350
X2 on what Bill said.
Red
Old Nov 7, 2012 | 08:16 PM
rockiestwins
Thank you will do this..
Old Nov 7, 2012 | 08:50 PM
ReBilld's Avatar
ReBilld
And, welcome to FTE!
Old Nov 8, 2012 | 09:26 PM
BIG ATS's Avatar
BIG ATS
brake problem
ok i had the same thing happen to me u need to replace both rear parking brake cables and free up the arm that the parking brake cable attaches to they bind up so when u apply ur brakes u are pushing out the shoes into the drum but i wont compress back to normal so the parking brake arm binds up take some pb blastster and work it loose then u will not have any problems
Old Nov 19, 2012 | 05:39 PM
RS/SS 67's Avatar
RS/SS 67
I have replaced all the rear brake and cable parts, What i learned after all that was that the front Calipers where not working correctly, I went so far as to order a rear disk setup that I never used. After changing out the front caliper's the brakes work as good as new. Hope this helps you out. Also I have a rear didk setup I would sell yah.
76F100guy
Sep 26, 2013 10:46 PM
imer37
Feb 7, 2008 12:03 AM
wagon burner
1997 - 2003 F150
Nov 2, 2004 04:27 PM
loanissa
Jul 31, 2004 07:53 PM
mhalter
Aug 1, 2003 07:59 AM
