Rear Brake Issue
Rear Brake Issue
Had a problem with rear brakes locking up. Only had 45K on the truck, but figured maybe 35 year old brake shoes weren't the hot setup Pulled the drums - piece o' cake - and had them turned; they'd never been off the truck before. Put in new shoes, hardware, and wheel cylinders. Worked great for awhile, and now they're locking up early again; feels like the drums have gone out of round.
The brakes aren't dragging. I don't overload the truck or brake heavily down mountain roads. I've never experienced this before, and I've been playing with cars since disc brakes were exotica.
Wheel bearing check by jacking the rear and giving top and bottom a good push and pull to check for loose bearings could eliminate that.
Also, how are the front brakes? If the rear is 100% and the fronts are weak that could throw it out of balance. I'd start with visual inspection and bleeding. Also rubber hoses with hidden blockage or swelling can cause weak brakes.
Beyond that and another visual of the rears, it could be the proportioning valve. They are available from inline tube if not from your local AP store.
When I brake hard, the rears lock, which is not conducive to stopping in a straight line Also gets a lot of unwanted attention.
Did the bearing check. There's a slight amount of movement; same on both sides. You can feel it, but you can't see it, so I'm guessing it's probably OK. Found the right adjuster hadn't been working. Pulled it apart, cleaned it up, and adjusted both brakes for a very light drag.
Rears still lock up too early, in my opinion. I may re-do the fronts with some different pads - currently using Wagner Thermo-Quiets - and, if that doesn't do the trick, look into a new proportioning valve.
Quiff_boy_Elvis
17
09-10-2012 12:57 AM
BIG ATS
03-15-2012 10:57 AM
4RINGS
09-01-2005 08:14 AM
