oil mods
Old Nov 7, 2012 | 03:21 AM
66crawler's Avatar
66crawler
oil mods
When restricting the oil in the heads with #90 Holley jets, how many jets are used? 1 per side or 2?
Old Nov 7, 2012 | 07:04 AM
Raptor119's Avatar
Raptor119
1 per side.
Old Nov 7, 2012 | 03:15 PM
66crawler's Avatar
66crawler
Thanks raptor, I've also read quite a few articles and the jet sizes recommend range from #69-#90? I drive for extended periods of time (over 1hr) over 3k rpm, what do you guys recommend?
Old Nov 8, 2012 | 10:19 AM
Raptor119's Avatar
Raptor119
Not sure Ihave a recommendation. I would error on the high side as you could starve the system with too small a jet. How small is too small? Not sure I know. I would install the 90 jet and call it good. It is a significant cut back from the original flow.
Old Nov 8, 2012 | 02:56 PM
66crawler's Avatar
66crawler
Yeah, most of what I read said use a .070 orifice but I'm going to go a little bigger, thanks raptor.
Old Dec 10, 2012 | 09:17 PM
pbear6969's Avatar
pbear6969
So why does so many people do this mod? Is it a must or just a good idea? I have ask several people that have had them for years and said they have never did it. Just curious.
Old Dec 11, 2012 | 01:29 PM
69cj's Avatar
69cj
I've never done it on my 428cj, original owner, and have never had a problem.
Old Dec 11, 2012 | 01:36 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The original oiling design allows far more oil to flow to the rockers than is needed, which in turn can cause the crank and cam to get less than what is needed.
Restricting the feed to the rockers just insures that more oil gets to the crank, where it can of greater benefit.
Old Dec 11, 2012 | 03:25 PM
montana_highboy's Avatar
montana_highboy
On a stock FE that will rarely see north of 3,500 rpms i don't feel it's needed, but a lot of guys do it for "peace of mind".
Old Dec 11, 2012 | 11:18 PM
travelerest's Avatar
travelerest
Ok,,, here is the answer to your question.
Most FE's that are raced use high volume oil pumps to supply adequate amounts of oil to keep their engines alive at high rpms. At sustained high rpms, you can pump to much oil into the valve covers that starves the crank, and cam. The two most used fixes for this is a deep oil pan to hold more oil and or restrictors in the heads to reduce the amount of oil going to the valves. Most FE racers do both modifications to keep their engines alive, along with other modifications to the block for better oil flow. As what was said above, for an engine that is not seeing high rpm, the modifications are not needed.
Old Dec 12, 2012 | 01:57 AM
pbear6969's Avatar
pbear6969
Ok got it. My engine will see 6k at times, but not for long periods. I was just curious. Thanks for the info.
jmcnair40
32
Jun 16, 2021 10:57 PM
thatguy71
Mar 6, 2014 11:13 AM
griff22imca
Mar 20, 2005 06:59 AM
debestuss
Jul 25, 2004 05:49 PM
fordboy1973
May 28, 2003 03:47 PM
