Coolant sample has no SCA's
Old Nov 7, 2012 | 11:05 AM
snknby123's Avatar
snknby123
Cool Coolant sample has no SCA's
I have a 2001 7.3L F250 i bought a couple months ago and noticed the green coolant is slowly dropping in the degas tank. I add some and it eventually drops again to the min within 2 weeks. The hoses look like they could be suspect so I will be getting new ones asap. I don't notice anything from the water pump weep hole.
I have done a lot of reading and bought the Fleetguard 3-way test strips to mesure the amount of additives in the coolant system. Well it came up bone dry so I added 16oz of DCA-4 and figure I will need more. I also have sent a oil sample to blackstone for analysis as the oil, to me, seems to have a green tint although it stays rock steady at the fill line.
My question is how long to wait before I test again? I warmed up the engine and drove it down the road and checked the degas bottle but it didn't look like it cycled any of the fluid, that I could tell, through the coolant system as the degas bottle was still the same color as when I added the DCA-4 additives.
Thanks for any input you can provide...
Diesel Noob
Old Nov 7, 2012 | 11:12 AM
guitarpicr's Avatar
guitarpicr
I would drive it about 10 miles & recheck it - Should be plenty to cycle thru - The color of the coolant probly wont change at all adding sca. Good luck
Old Nov 7, 2012 | 11:20 AM
nlemerise's Avatar
nlemerise
Diesel Noob
If it was me, I would switch over to a heavy-duty ELC and then you never have to check SCA's again. See this link...
Old Nov 7, 2012 | 11:21 AM
snknby123's Avatar
snknby123
Yep, I think switching to HD-ELC is in the very near future. hopefully I don't have a leak from cavitation already.
Old Nov 7, 2012 | 12:40 PM
snknby123's Avatar
snknby123
Is it normal for the degas/expansion level in the tank to rise when you have driven the truck then when it cools the level drops? That's the whole purpose right not to blow the radiator etc...
Old Nov 7, 2012 | 02:34 PM
guitarpicr's Avatar
guitarpicr
Yea- As the water heats up it expands -This is normal. Mine usually raises & falls within 1" or so of the full line
strokeithard
16
Mar 2, 2017 02:41 PM
Gyrene4Life
6.7L Power Stroke Diesel
16
Apr 9, 2015 08:44 PM
Canadian F250
Nov 3, 2012 02:15 PM
THE KING
Mar 31, 2007 02:40 PM
tomtexas
42
Nov 26, 2004 01:51 PM
