Bilstein 5100 order help
Old Nov 5, 2012 | 04:58 PM
F350Jay's Avatar
F350Jay
I've decided on the Bilstein 5100 series shocks for my 2011 F250. Here's my situation. I'm replacing the OEM F250 2" blocks (or spacers) with 4" ready lift blocks (which I believe is what the F350 has). I'm also adding a 2" autospring leveling kit. Bilstein and 4 Wheel Parts says the front should be part #24-186018 and the rear should be #24-186066. I'm good with the fronts but I'm unsure on the rear and this is why... On Bilsteins website it states that a F350 with no lift (which is the height that I'm after in the rear) requires part # 24-186025. Big Sarge used the 025 part number on his video.
Basically a F250 with a 2-4" rear lift requires part 24-186066 and a F350 with no requires part 24-186025
Need some help. Are the mounts different or something. Thanks
Old Nov 5, 2012 | 09:25 PM
my996duc1's Avatar
my996duc1
I did a similar setup.
- 4" ready lift rear blocks (F350 blocks are 3.75" tall)
- Bilstein leveling kit with front springs and shocks.
- Bilstein rear shocks
Here is the link with all the info when I did mine.
https://www.ford-trucks.com/forums/1...tall-f250.html
As you can see in the link above, I am running the 24-186025 on the rear.
I would give Bilstein a call and ask them directly what is the difference between the two different rear shocks......
_
Old Nov 6, 2012 | 05:19 AM
P.Bronner's Avatar
P.Bronner
That IS a head scratcher. I can't see why the #025 wouldn't be correct. I'd bet the #066 is the next longer shock, which would accommodate an F250 w/4" block (or a 350 w/2").
Old Nov 6, 2012 | 05:26 PM
F350Jay's Avatar
F350Jay
I spoke with Bilstein out of Cali and 24-186466 (not 186066) is correct for a F250 with a 4" block
Old Nov 7, 2012 | 10:00 AM
my996duc1's Avatar
my996duc1
Be interesting to find out what the difference is between the two.
When I bought mine the correct part number was the 186066, wonder what changed.
parnass
Jan 4, 2017 06:58 PM
dirtymutt
6.2L V8
34
Jul 28, 2015 06:27 PM
dylansf23
Oct 21, 2013 08:58 PM
12ozd
Oct 7, 2009 12:08 PM
jvoigt
Aug 14, 2007 07:10 PM
