block heater
Old Nov 5, 2012 | 08:16 PM
jayro88's Avatar
jayro88
Originally Posted by JDFan4010
I would like to use my block heater, but fear the whole cracked block thing. Are the original units ok to use? If so how long could they be plugged in.
Sorry-this is my first 7.3, and my old 6.9 didn't have this issue.
I could be wrong since I am new here, but I thought it was the early 6.9's that had the block cracking issue and that the newer 6.9's and 7.3's were fine. Am I wrong?
Old Nov 5, 2012 | 08:19 PM
jayro88's Avatar
jayro88
Originally Posted by kevind95
That's my next a little project so I probably get on that tomorrow OH somebody said in an earlier post that the heater itself scwews into a freeze plug. Will water come streaming out when it is removed ?
Before pulling all that just check the cord and then the heater with an ohm meter. The resistamce will vary depending on the wattage, but you should get continuity. If you dont at the plug, then test the actual heater. If you have it at the heater, then all you need to do is fix the cord. I had this exact issue last week. Splices the cord, and I am back in buisness.
Old Nov 5, 2012 | 08:30 PM
bashby's Avatar
bashby
That is correct.
Old Nov 5, 2012 | 11:25 PM
JDFan4010's Avatar
JDFan4010
Ok, good to know, so I'll be using my block heater on a timed circuit then.
Old Nov 6, 2012 | 06:19 AM
bashby's Avatar
bashby
In case anyone's wondering, I figured out that at my electrical rate, a 1000 watt block heater costs about $0.10/ hr to run.
Old Nov 9, 2012 | 10:05 PM
kevind95's Avatar
kevind95
Ok I found that the wire at the plug going to the heater itself looked like it got pulled and was seperated away.(not sure but probably happened when I pulled away while it was still plugged in Do you think that would happen?lollollollollo)
Old Nov 10, 2012 | 12:07 AM
pro3qtr's Avatar
pro3qtr
Sounds like a WIN !!!
Old Nov 10, 2012 | 04:22 AM
Scratcher's Avatar
Scratcher
Early 6.9 blocks up to mid 85 had a thinner block around the heater causing it to crack. From mid 85 onwards the blocks were thicker to address this issue.
My current rebuilt 86 has no block heater and starts fine with a healthy set of GP's and batteries.
On cold mornings I run a mains powered fan heater for 30 minutes in the cab to get rid of ice and snow before heading out. That usually gets me by until the thermostat opens and allows heat through.
I have a KATS in line coolant heater on the shelf. Once I lose compression and she becomes harder to start I will install the KATS
EXTREMEFUN1300
Dec 13, 2010 10:56 PM
dieselphil
Nov 16, 2008 02:58 PM
csangster
May 14, 2008 11:38 PM
rcrane511
Dec 19, 2007 03:46 AM
Tazzmann
Oct 28, 2006 06:45 AM
