block heater part #
Old Nov 16, 2008 | 09:38 AM
dieselphil's Avatar
dieselphil
block heater part #
I was wondering if anybody had the part number for the the block heater on 96, 7.3 the one they gave me at napa isn't the right one.also how do you test the heater itself.I have a multi meter but not sure how to test if heater is good. thanx. Phil
Old Nov 16, 2008 | 09:55 AM
BlueMule's Avatar
BlueMule
F4TZ-6A051-A is the heater and F4TZ-6B018-B is the cord
Old Nov 16, 2008 | 09:58 AM
dieselphil's Avatar
dieselphil
right on, thanks rodney
Old Nov 16, 2008 | 10:10 AM
dieselphil's Avatar
dieselphil
what about testing it? how do I tell if heater is good?
Old Nov 16, 2008 | 10:17 AM
Hussler's Avatar
Hussler
IIRC the resistance should be between 10 - 20 ohms. Last time I checked mine was 14 ohms.
Old Nov 16, 2008 | 10:55 AM
dieselphil's Avatar
dieselphil
thanks, mine is definitly dead.
Old Nov 16, 2008 | 10:59 AM
BlueMule's Avatar
BlueMule
Jim
Where did you find the resistance value for a good heater? I just spent half an hour going thru the Helms manual and all it says in the pinpoint tests is to check the continuity in both the cord and heater separately and replace which ever one shows an open circuit. I really expected to find an ohm range for a good heater but it just wasn't there.
Old Nov 16, 2008 | 11:00 AM
Hussler's Avatar
Hussler
Cut the plug off and recheck. Most failures occur at the plug end and you have nothing to loose. If so then just bye a replacement plug .. cheep fix.
Old Nov 16, 2008 | 11:09 AM
Hussler's Avatar
Hussler
Originally Posted by BlueMule
Jim
Word of mouth .. this question came up a while back. I remembered tj responding indicating it should be between 10 - 20 ohms. Being the curious guy I am I checked mine at it measured at 14 ohms.
Old Nov 16, 2008 | 11:26 AM
BlueMule's Avatar
BlueMule
Yea me too! I just checked mine, 16.3 with the cord attached and 14.5 at the heater. I guess that's what an unused one should read as mine has never been plugged in.
Phil,
I wouldn't cut the plug off the cord just yet, unplug the cord from the heater and check each piece individually.
Old Nov 16, 2008 | 01:00 PM
dieselphil's Avatar
dieselphil
I checked the heater by itself and it showed no resistance the cord was already bad. by the way would that be the ford part number and can I get it any where other than ford.
Old Nov 16, 2008 | 01:40 PM
BlueMule's Avatar
BlueMule
Yeah those are Ford numbers, I'm sure you could get it from IH but I don't know the part numbers. I'm kinda surprised that NAPA doesn't have it, maybe it was just the counter guy that didn't know how to look it up.
Old Nov 16, 2008 | 02:58 PM
Hussler's Avatar
Hussler
The good new is I do have the IH parts breakdown .. bad news it's in Spanish. That being said the pictures indicated the heater element is part # 1814323C1. It does not show the actual heater cord.
GTBksRule
Jan 28, 2013 11:39 AM
tje2015
Jan 26, 2012 07:09 AM
dyna
Jan 2, 2012 11:09 AM
Learath
Dec 4, 2006 10:18 AM
automaticj5
2004 - 2008 F150
Nov 17, 2006 09:27 PM
