Cant Find Reverse
Old Nov 4, 2012 | 02:17 PM
FlatBlak's Avatar
FlatBlak
Cant Find Reverse
Got my new transmission installed (full manual valve body, reverse pattern, transbrake (art carr) Ford c6) installed the new shifter (b&m quicksilver)
hooked it all up as per directions. getting into park is tight. neutral, 1st, 2nd 3rd. is perfect. but i cant find reverse... at all. wondering if anyone can help me. this is a fresh rebuilt transmission, all components, lines, filter, fluid is new.
Old Nov 4, 2012 | 02:26 PM
FlatBlak's Avatar
FlatBlak
what i mean by cant find reverse is the truck runs and drives in every other gear, but i cannot find reverse at all, so im worried i have no reverse and what to check for to see if i do or not?
Old Nov 21, 2012 | 06:43 PM
FlatBlak's Avatar
FlatBlak
anyone? re adjusted the shifter cable all over again, still nothing
Old Nov 24, 2012 | 10:47 AM
stuart1's Avatar
stuart1
What happens if you disconnect the cable and shift it at the transmission?
Old Dec 2, 2012 | 04:49 PM
FlatBlak's Avatar
FlatBlak
Did just that today, does not have reverse going anywhere no matter what rev, played around with the kickdown assembly thats still attached but doesnt really have a purpose being that its full manual, still nothing, to the driveshaft, to the wheels, nothing.
Old Dec 2, 2012 | 07:15 PM
FlatBlak's Avatar
FlatBlak
K so after doing some google'ing, some guys have a problem with this when somethings up with the valve body, so decided to get underneath.
First i drained the oil, and wasnt happy that i saw clutch/shavings on the magnet. then i pulled the pan down, wasnt happy about it being all over the bottom of the pan. The rest of the pictures are for you to judge, if you can see a problem, please let me know. this truck has been off the road too long
Old Dec 2, 2012 | 09:08 PM
FlatBlak's Avatar
FlatBlak
just another quick question after another observation:
checked my torque converter to flywheel clearance, its between 11/32 to 3/8 clearance. if this is too spread out could this be the problem?
Old Dec 2, 2012 | 11:12 PM
85e150's Avatar
85e150
What torque converter did you use? Did you buy this trans from someone or is this a diy job?
Old Dec 3, 2012 | 05:08 PM
FlatBlak's Avatar
FlatBlak
The torque converter is a Hughes, trying to figure out a way to shim the torque converter down to 1/8". Talked to the local c6 god named Frank Merkl this morning, he asked me if it was an external brake, which it is. he seems to think the problem why i cant find reverse is because i have to engage the brake in reverse, which kind of makes sense as ive never hooked it up. The transmission was built in vegas as well as 5 others. Brand new i bought it off of a fellow racer. I think I may have this resolved, just in the middle of putting it all back together lol
Old Dec 3, 2012 | 09:10 PM
jk080's Avatar
jk080
Transmission Rebuilder
The pictures of the pan don't look good, I hope all that came out of the cooler instead of the trans. I appears to have some damage to some clutches from all the black debris. Maybe a air check of the direct and low reverse clutches with the valve body off will show something.
Old Dec 3, 2012 | 10:46 PM
FlatBlak's Avatar
FlatBlak
I'm still concerned about the shavings in the pan as well, but hard to say where it came from. but i buttoned it all together, hooked up the transbrake to the reverse lights on my shifter, good to go now.
DieselBurner153
Mar 26, 2013 12:18 AM
grande1972
1983 - 2012 Ranger & B-Series
Mar 17, 2013 06:21 AM
2004 xlt 5.4
2004 - 2008 F150
Dec 29, 2010 07:16 PM
TennesseeMustangPerf
Mar 12, 2010 05:57 PM
FLgargoyle
Jul 20, 2006 12:15 AM
