Sponsored by: Real Truck
Having trouble going into reverse sometimes...
Old Mar 12, 2010 | 03:11 PM
TennesseeMustangPerf's Avatar
My 2003 SD sometimes will not engage in reverse from neutral (like it still is in park). When I put it in first, the truck takes hold, and I can then put it in reverse and it will engage. Any ideas? TSBs? Thanks!
Old Mar 12, 2010 | 05:28 PM
radracer17's Avatar
radracer17
Not sure if this will help you, but my truck was having issues when I tried moving the lever-felt "loose", especially in reverse. Long story short, I found the bracket that holds the cable end at the column under the dash was loose, tighened the two torx screws and good as new!
Old Mar 12, 2010 | 05:57 PM
Thanks for the reply. Unfortunately for me though, my lever is tight and the indicator is moving properly to the "reverse" location on the cluster.
