Another Pitman Arm Question
Old Nov 4, 2012 | 10:42 AM
sammie0126's Avatar
sammie0126
I am getting ready or order a new pitman arm for my 2000 EX in advance of getting a new Red Head gear box. Read several posts on this and people struggling with the 36 spline vs 32 spline and have seen several state all Excursions have 36 spline. Looked on Ebay; Raybestos and Moog both maybe have one that probably fits but information is so bad on the 36/32 issue not wanting to risk that, so broke down and went to Ford and looked it up.
Two things surprised me:
1. The OEM ones are actually a little bit cheaper than the ebay options. Don't think there is much "upgrade" room in this part so nothing gained by paying more for aftermarket.
2. Even Ford lists both the 32 spline and the 36 spline for the 2000 Ex and that is with my VIN entered before searching.
Buy 2000 Ford Excursion Parts | FordParts.com
I know the "real" way to be sure, is to go out and count the splines on the box. Tried that but this is one part in my front end that hasn't been replaced, and it is covered in gunk, grease, rust, crud and with the reach I couldn't get an accurate count. I was able to clean off the bottom of the arm and get the exact part number, but since Ford only lists 4 digits of the part number and the prefix and suffix change by vehicle is was of little help. I can't find this exact part number in any search.
Part number on the bottom of my pitman arm is YC35-3590-AB
Anybody out there who has that part number on their pitman arm that could count their splines for me and confirm I need the 36?
Old Nov 4, 2012 | 01:10 PM
timf150's Avatar
timf150
Tousley Ford is one of our sponsors for FTE. Give them your VIN number and information about your X and they can get you the correct part for your vehicle and a good price.
Since you believe its the original equipment then it should be easy for them to get the correct part.
Ford Truck Enthusiasts Forums - View Profile: FORDSVTPARTS
FORDSVTPARTS
Tim M
Old Nov 4, 2012 | 02:24 PM
sammie0126's Avatar
sammie0126
Thanks should have thought of them, used them several times and they are very helpful.
Old Nov 4, 2012 | 03:00 PM
wpnaes's Avatar
wpnaes
Any reason to get a new one? Do the old ones wear out over time? I'm thinking of getting a dropped arm with the leaves I added to level out the Ex.
Old Nov 4, 2012 | 03:06 PM
sammie0126's Avatar
sammie0126
Couple reasons.
One when I got this truck it was horribly rusted and that includes the pitman arm, but it and the gear box are the only two things underneath I haven't replaced or restored. See pic on what I mean when I say rusted.
Second it's only about $40 and I don't have the tools or know how to pull it to move it to my new gear box. So thinking it will be worth $40.
Old Nov 4, 2012 | 03:59 PM
wpnaes's Avatar
wpnaes
Sammie, I think you posted the wrong pic. Thats the anti-sway bar attachment to the axle. Agree though, mine broke off 'cause of rocks rather than rust.
Old Nov 4, 2012 | 04:04 PM
sammie0126's Avatar
sammie0126
No, I wasn't trying to post a picture of the pitman arm, don't have one was just posting a pic of what the underside looked like. You can apply that and guess what the pitman arm looks like as well. That axle is gone replaced with a D60 along with the mounts and bar, but pitman arm is still what came on the truck. Took a dremel and 20 minutes just to get it clean enough to get a part number off the thing.
Old Nov 4, 2012 | 04:29 PM
wpnaes's Avatar
wpnaes
Got it .
sgrol
28
Nov 30, 2019 07:39 AM
ghott
Mar 25, 2016 12:00 PM
JJensen79
Oct 9, 2013 08:36 PM
DemonRace6
Sep 13, 2011 01:19 PM
robertr
Apr 17, 2009 09:27 AM
