6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
backup camera help.
Old Nov 3, 2012 | 02:33 PM
fordtruggy's Avatar
fordtruggy
backup camera help.
Now suddenly my backup camera screen in the mirror is solid blue. Come on as blue for a bit then goes off. Any ideas where to start? Thanks!
Old Nov 3, 2012 | 04:32 PM
wp6529's Avatar
wp6529
The first place to check is the connector under the tailgate. If it wasn't latched properly it could wiggle loose. The camera has it's own 2A fuse also, F73 in the underhood BJB. There isn't much to the wiring:
Old Nov 3, 2012 | 10:34 PM
fordtruggy's Avatar
fordtruggy
Thanks man, Ill take a looksie at the plug and see what i can see.
Old Nov 4, 2012 | 11:54 AM
RM2738's Avatar
RM2738
It's coming on blue then shutting off because its not getting signal. Kind of like many TV's.
Old Nov 4, 2012 | 08:55 PM
fordtruggy's Avatar
fordtruggy
That makes perfect sense! But the plug under the tail gate looks ok. Maybe the camera is dead
Old Nov 4, 2012 | 09:07 PM
RM2738's Avatar
RM2738
Fuse? Plug behind mirror? Have you had or done any work lately to your truck?
Old Nov 6, 2012 | 07:34 AM
wp6529's Avatar
wp6529
There are some seven connectors between the camera and the mirror, all potential problem spots.
The video signal is an ordinary NTSC composite signal the same as you get out of any inexpensive surveilance camera or the video out of many gadgets.
You can connect any such source to the truck side of the connector at the tailgate, put the truck in reverse and you will see the video in the mirror if the wiring is all good from the connector back to the mirror.
If you tow campers or other enclosed trailers, you can buy the cable that goes from the camera module in the tailgate to the under tailgate connector for about $50, cut the camera end off the cable and wire the remaining portion that has the connector that mates under the tailgate to a backup camera on your trailer.
You need to use a specific backup camera to get the reversed video you expect, but such cameras are available as cheap as $30 or so. You can also buy another of the nice Ford cameras which also provide the guide lines, and then you just cut that cable in the middle and extend it as needed for the trailer.
Old Dec 14, 2012 | 06:55 PM
fordtruggy's Avatar
fordtruggy
Dealer said it needs a new camera. They wanted 600 something bucks for it so i said forget it.
Old Dec 14, 2012 | 07:12 PM
RM2738's Avatar
RM2738
Oops.... $424.XX.
That's a little much.
Old Jan 22, 2016 | 09:05 AM
Seaeagle1's Avatar
Seaeagle1
Camera on my 2012 F-150 just started acting up. Went to Ford dealership and they said it needed to be changed. Have extended warranty with $100.00 deductible. There is no way to change the camera without changing the Ford logo, because it is built into the logo. Had to purchase the logo for $48.38 plus tax and shop supplies. Owned more Ford vehicles than I can remember. This just isn't right to have to pay to advertise the Ford logo.
Old Jan 22, 2016 | 09:57 AM
FordService's Avatar
FordService
Official Ford Rep
Welcome to the forum, Seaeagle1. Just to clarify, did you proceed with having the logo replaced? How many miles are on your truck?
Crystal
Old Jan 22, 2016 | 01:55 PM
ginomachino's Avatar
ginomachino
Sorry for your troubles, and sorry to highjack your thread, but is there a way to make the camera to stay on even when it isn't in reverse?
Offshore_Outlaw
May 3, 2019 05:41 PM
TNT in Round Rock
Jan 29, 2017 04:21 PM
Tore
Jan 16, 2017 04:36 PM
rustyoldford
2009 - 2014 F150
Jul 1, 2016 05:47 AM
Sweetpea02
Jun 7, 2013 09:04 PM
