4x4 problems
Old Nov 2, 2012 | 09:24 PM
lowbed dud's Avatar
lowbed dud
4x4 problems
this is on 02- 250 , have found one fuse #111 30a is there a relay some were?
no lights on dash, no sound at t-case, have a snap-on scaner that shows the on dash switch is working, any help app. al
Old Nov 3, 2012 | 12:28 AM
1fixitman's Avatar
1fixitman
Electronic Shift On the Fly (ESOF) fuse is #17 and it should be a 30 amp fuse. This fuse is under the hood. Fuse 11 under the hood is washer fluid pump, windshield wipers and relay for wipers. I am going off of my owners manual for a early 99.
Look thru your owners manual near the back for all of your fuse designations. They will not be printed under the fuse panel area.
Dwayne
Old Nov 3, 2012 | 03:34 AM
Tugly's Avatar
Tugly
2002 truck
Central Junction Box (CJB) fuse 27 (15a) powers the controls for...
  • Auxiliary Climate Control
  • Heated seats
  • Vacuum pump motor
  • speed control
  • Overhead console
  • Brake shift interlock
  • Electronic Shift
  • On the Fly (ESOF) solenoid
  • Digital Transmission Range (DTR) sensor
Fuse 59 (30A) powers the transfer case relay.
Old Nov 3, 2012 | 06:01 AM
lowbed dud's Avatar
lowbed dud
thanks for the help, when it gets light i will see. i don't have owners m' just a pdf file got the other number from.
Old Nov 8, 2012 | 06:26 PM
lowbed dud's Avatar
lowbed dud
not having much luck all fuses are good, can't find #59 FUSE. any one know were 4x4 shift modguel is located on this truck, 02 250
Old Nov 21, 2012 | 04:35 PM
lowbed dud's Avatar
lowbed dud
UP date got 4x4 to working turned out to be bad connection on t-case shift motor, thanks tuglry for digrams
ROADHOGE250
Mar 24, 2019 06:55 PM
cm6pack
Apr 24, 2013 10:42 AM
Big-Red-89
1997 - 2003 F150
Jul 12, 2011 09:12 PM
tomb391
May 24, 2009 11:13 PM
KRJ
Oct 23, 2007 10:01 AM
