E250 HEADLIGHT UPGRADE
Old Sep 18, 2014 | 07:46 PM
ROADHOGE250's Avatar
ROADHOGE250
Installed HELLA 7x6 lined lens conversion for a trip over the Rockies into Wyoming down thru Utah.
Not that we’re driving at night ! I am over the line on not seeing the berm or insides of sharp low speed turns. Ford’s 2 headlamps recessed into the black nose 2008 grill do not light the berm. A disaster, criminal under design.
The Ford lighting experience is mostly transient….cursed then let slide.
Worse, illumination from the Ford wiring/lamp units was variable over 100K miles.
NOT THIS TIME.
HELLA finally appeared on Summit Racing’s catalogue with a hi/low beam conversion upgradeable to 80/100 watts from 55/60w.
Easy replacement: Lamp units side’s sprout 2 ears squeezing into Ford’s housing.
Wiring here turns out hi becomes low, low to hi so wires need switching. The bulb unit seats against Hella’s housing on a brown rim with some tweaking of front and rear tabs, removal of under tabs at the rectangular punchout where the housings small vertical locator fin sits thru.
Bring 2 quality needle nose pliers. One large one small. Have a diode wire twister pins on a small needle nose ? Super. If the spring clip needs bending, the bender…exercising 3D intelligence, holds one side stable with pliers, maybe linemans, then bends the other side.
You watched Jeep Man install round HELLA ? No mention of inspecting the bulb unit’s seating. I would guess there are a few HELLA conversionists wandering around with cockeyed bulb units.
So. What happened ? Around the corner into darkness we have a Blvd runs thru Cow Slough Swamp off the Bass property into the Gulf of Mexico.
I was pleased as Punch. Niagara Falls Dude. The Ford Lighting Tunnel replaced with a broad evenly illuminated road and berm with distant sings glowering back.
EYEYEHAHHAHHAHAH ! LIGHT ROAD BUFFALO FRENCH FARMERS…
Coons and possums danced on the berm.
You know the feeling: “ Aw was this worth the trouble” ?
NOT HERE !
On hi beam with low stalk. Low beam on hi stalk had a fine cutoff with excellent berm lighting.
Yes, 15% plus brighter overall than Ford but focus…wonderful.
There are 450’s peaking over a roof rack spoiler for ultimate berm ID.
We know where we are now.
Two bolts top 2008 grille light ‘bezel’ …the entire large plastic surrounding park and headlamps.. and 2 bottom hiding back of the bumper with one plastic ring pin shaft on the outboard side pulls out.
4 12ga wires for each filament run direct from the battery supplies .25 volts plus to the conversion, over what Ford’s wiring feeds.
I haven’t plugged the desert lighting 12GA relay unit in for a test but have a photo. I’ll get back after testing the relay wiring for Ford anti-mod surprises,
Wiring: http://www.revlimiter.net/mods/pix/moss_relays.gif minus the dioded double connection on left
Relay: HELLA 4RA003 510 26
Housing: Walmart School days pencil box atop battery. Closed with 3M electrical tape shingled over seams. Relays mount on a plastic bar, Bottom box has 4-6 holes melted thru with a propane heated nail held with vice grips. Wire holes closed with 3M 5000 boat caulk or Loctite General Adhesive available at Home Depot and Walmart. Haven’t tried the Loctite on whatever the box is made from. The 3M sticks, cures slowly.
Hella conversion: http://www.summitracing.com/parts/hla-003427811
Look thru Hella’s AUX lighting while there.
Wire gauge/voltage calculator
http://www.powerstream.com/tech.html
Hella advice:
<table width="92%" style="width: 92%; border-collapse: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt;" border="0" cellspacing="0" cellpadding="0"><tbody><tr style="mso-yfti-irow: 0; mso-yfti-firstrow: yes;"><td style="padding: 0.75pt; border: rgb(0, 0, 0); background-color: transparent;">Reduce the voltage drop to the bulbs
</td></tr><tr style="mso-yfti-irow: 1; mso-yfti-lastrow: yes;"><td valign="top" style="padding: 0.75pt; border: rgb(0, 0, 0); background-color: transparent;">
By bypassing the standard wiring with relays the voltage to the headlamp can increase, giving improved performance from any bulb. Typically standard wiring is relatively thin and a 1 volt drop is common to the bulbs. When replaced with higher capacity cable and relays this voltage drop can be reduced. A 10% drop in voltage (1.2V) equals 33% drop in light output. Your local Auto Electrician will be able to offer this service. (0800 4 HELLA)
</td></tr></tbody></table>
http://goo.gl/luQga9
Old Sep 19, 2014 | 05:58 AM
JWA's Avatar
JWA
Am I alone here that after reading said "WTH is this about?"
I mean I get its about some sort of new headlight system but what about before/after photos? Installation, effect or difference/improvement over previous set up?
Perhaps it's the out-sized font that confuses me?
Old Sep 19, 2014 | 10:08 AM
YoGeorge's Avatar
YoGeorge
I'm with ya, JWA. I'd be interested in reading about a headlight upgrade, but it's hard when presented as poetry or creative writing that is too cryptic to actually understand. I was lost with Jeep Man and Cow Slough Swamp references. The link to the picture works. Looks like a headlight.
George
Old Sep 19, 2014 | 11:17 AM
JWA's Avatar
JWA
George
Perhaps this was intended for another forum wherein obscure references et al would be more in context?
Beats the hellouta me!
Old Sep 19, 2014 | 12:55 PM
ROADHOGE250
Next post, I'll check with you for approval. Jeep Man is on Utube. The paste in from Word left Utube out. Could be a round unit has more centering than a variable sized unit...as with the 'ears' snugging the 7x6" into Ford's housing. The first photo, of the Hella conversion unit in place displays lensing for berm illumination.
Old Sep 19, 2014 | 01:02 PM
YoGeorge's Avatar
YoGeorge
Thanks for the clarification. No approval needed. But most of us don't have a half hour to read a post, click on all the links in order, etc. Coons, possums, and cow slough also on Youtube? My headlights work OK for what I need although I am naturally curious about interesting modifications...
Niagara Falls....slowly I turn, step by step, inch by inch...
Thanks and take care,
George
Old Sep 19, 2014 | 01:17 PM
dubyaohohdee's Avatar
dubyaohohdee
I am not one to talk, but the OP only has 3 posts and just registered. It definitely reads weird. Some sort of Ad bot or something probably.
Yep: Spam for sure. http://www.motorsforum.com/ford_truc...hts-33770-.htm
Old Sep 19, 2014 | 08:01 PM
ROADHOGE250
Niagara Falls generates electricity, Plato generates Pizza.
So why are coons and possums dancing on the berm ?
Packing the now spare OEM headlamps, I see berm lines on the OEM lens but only for one berm side unless one lamp installs upside down. Just back from Ford parts and no, I do not see a left unit/right unit listing.
Go look.
Perspective here is an E250 owner needs seeing only one berm side, the right side when in fact there are 2 sides to everything.
Search Google for: Bass Cow Slough Gulf of Mexico
It's a swamp...DARK !
If an E250 owner has $100...and what E250 owner doesn't ? Buy a set now before daylight shortens with the onset of winter. You guys have noticed this ? No better upgrade for a bill.
The post covers the grnd.
In forums, generally, any creativity brings your response whether kidding or critically serious like Custer or the Alamo. That the writing covers important information or tech developments is irrelevant.
Old Sep 19, 2014 | 10:13 PM
tx2sturgis's Avatar
tx2sturgis
Thumbs up let there be light
Wow.
Ok...I added Rigid LED lighting to my e250 and also dropped in a couple upgraded 6054 halogen lamps. (non-composites on my cargo van)
On low beam everything is about what the factory gave me...but I use a relay to trigger the Rigid D2's on when the high beams come on and let me tell you guys....thats some 747 landing light bright!
WhooHoo!
No cow dung here.
Old Sep 19, 2014 | 10:37 PM
YoGeorge's Avatar
YoGeorge
It's all good.
Surprise bonus is that these headlight tips will also work on E150's and E350's.
Weekend is here!
George
Old Sep 21, 2014 | 01:58 PM
Mach5's Avatar
Mach5
One of my "to-dos" is to upgrade the rather paltry lighting on my 99 E-350.
Old Mar 24, 2019 | 06:55 PM
turbogus's Avatar
turbogus
I've used the Hella Vision plus headlight conversions on almost all of the rigs I've had since the '80's and they are far superior than any other I've seen. More recently I've found Flosser H4's at 140/100 and, PROPERLY aimed they are superb.
DieselTrap
May 31, 2012 01:35 PM
Tugly
44
Mar 16, 2012 05:54 AM
Big-Red-89
1997 - 2003 F150
Jul 12, 2011 09:12 PM
F 250 6 liter
Mar 3, 2011 08:44 AM
rbloodhound
Louisiana Chapter
1093
Feb 1, 2008 06:53 AM
