weird wiper behaviour
Old Nov 2, 2012 | 03:11 PM
Greg5OH's Avatar
Greg5OH
my winsgield wipers do some weird things. doesnt matter if its fast or slow speed. Sometimes they will run forever no issue, sometimes they get stuck, then after a minute they will resume normal operation. Sometimes i joggle the switch from off to slow, sometimes that gets em going sometimes not. Any ideas?
Old Nov 2, 2012 | 04:22 PM
Puddy's Avatar
Puddy
Sounds like you may need a new wiper switch/turn signal.
*edit*
Just realized you have a 91, my apologies.
I would try checking at the motor for loose or damaged wires. But your saying if you play with the **** it works. Well I would grab a spare switch and try it out.
Old Nov 2, 2012 | 07:27 PM
Greg5OH's Avatar
Greg5OH
Any idea how much current it draws? The wires were replaced by the previous owner and seems i see some burn marks in areas, he used what seems like 14awg speaker wire
Old Nov 2, 2012 | 07:40 PM
Eddiec1564's Avatar
Eddiec1564
Loose magnets inside the wiper motor would do what you described. I went through 3 motors before finding what was going on.
Over the years the glue will degrade holding the magnets in place. They will move around slowing down the wipers then stopping. Sometimes messing with the switch will cause the motor to rotate enough so the magents get back in proper timing for the armiture.
I cleaned out the motor case and re-epoxied the magents back in place. The 1st motor I didn't get the magnets in proper place and it would not run. The 2nd and 3rd motors are working to this day!
Old Nov 2, 2012 | 07:43 PM
Greg5OH's Avatar
Greg5OH
^thanks ill take it off and have a looksie as well as replace those wires
Old Nov 2, 2012 | 08:00 PM
fdude64's Avatar
fdude64
could be slop in the linkage also causing it to bind up
Old Nov 12, 2012 | 08:35 PM
Greg5OH's Avatar
Greg5OH
Eddie i think you hit the nail on the head. wipers started behaving weird soon after turned on today, turned off while turning left, turned back on when i popped the clutch a bit, got stuck slowing down, turned back on when i bumped the truck a bit.
loose magnets? ill tr yot take it apart tomorrow and see what sup in there
Old Nov 13, 2012 | 04:13 PM
Greg5OH's Avatar
Greg5OH
ok how the heck do you take this motor off?!
Old Nov 13, 2012 | 04:53 PM
garrett_8's Avatar
garrett_8
my 93 does the same time, its sketchy doing 75 down the highway in the rain and the wipers stop
Old Nov 20, 2012 | 09:40 PM
400M_Bronco's Avatar
400M_Bronco
My wipers only work on the high setting only! not sure why... they start to hesitate and pause all crazy like too after bout 5min or so.
Tony_C
Sep 10, 2011 09:17 AM
dbredinger
1997 - 2003 F150
Apr 27, 2010 07:07 PM
4byford
Electrical Systems/Wiring
Jan 7, 2007 06:23 PM
Green Streak
Apr 1, 2005 11:09 PM
gskett
Jun 13, 2004 05:54 AM
