shift collar pointer
Old Nov 2, 2012 | 04:48 AM
The Masked Rider's Avatar
The Masked Rider
Anyone know where I can get that little plastic pointer that slides into the cutout in the shift collar on a 65-66 automatic shift...? Are they still available or is there anyone that might have one in their pile of goodies?
Old Nov 2, 2012 | 07:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by The Masked Rider
Anyone know where I can get that little plastic pointer that slides into the cutout in the FoMoCo service part replacement shift collar on a 65-66 automatic shift?
Little plastic pointer: Your shift collar has been replaced with one from a 1973/77 F100/350 (and etc), as it uses D3TZ-7A110-A plastic pointer that slides into a groove in the collar.
The original 1965/72 shift collars had the pointer made as part of it. I located exactly 1 NOS if you're interested.
D5TZ-7228-A (replaced C5TZ-7228-A & B, C9TZ-7228-A, D3TZ-7228-A) .. A/T Shift Collar KIT-includes pointer / D5TZ-7228-A kit available from Ford.
Applications: 1965/77 F100/350 / 1973/77 Bronco / 1975/77 Econoline // MSRP: $65.98 / FTE sponsor tousleyfordparts.com price: $43.55.
D3TZ-7A110-A .. Shift Dial Pointer / Obsolete / How many would'ja like?
BELL-MCCALL CO. in Hamilton MT has 1 = 406-363-2011 (closest source to artichokeville).
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
JST AUTOMOTIVE in Lebanon TN has 3 = 615-443-3086.
WESLEY OBSOLETE PARTS in Liberty KY has 4 = 606-787-5293.
PARTS INTERNATIONAL in Farmers Branch TX has 5 = 888-727-0418.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 245 = 800-476-9653.
Old Nov 2, 2012 | 03:38 PM
The Masked Rider
Thanks Bill. You are correct. I forgot that I also switched out the steering column when I switch everything from a 74' along with the power steering. DAAAAAAAAAAAaaaaaaaaaaaaaaa
Old Oct 27, 2020 | 12:24 AM
My1966F250's Avatar
My1966F250
I have a 1966 F-250 that he shift lever does not stay in park that is more than likely caused by wear. what part do I need to replace, I have not taken it apart yet.
Old Oct 27, 2020 | 07:56 AM
AZSCAWPION's Avatar
AZSCAWPION
Welcome to FTE. In the future, starting a new thread will usually yield better replies rather than piggy backing onto an older thread.
That being said, often the detent plate can be worn and causing your problem. Not always the case though so be sure to inspect the shift lever as well. Check for wear at the point it engages the plate (there's also a spring hidden in there too) and also that it is firm where it mounts in the collar. You should also check and adjust the linkage as it relates to the transmission. All can/will play a part in your issue.
See here for some photos from when I tackled mine https://www.ford-trucks.com/forums/1...l#post17758143
Tony
kenny nunez
May 27, 2019 01:46 PM
tracer3612
Oct 2, 2014 10:05 AM
orentzroy
May 21, 2014 11:02 AM
rande bly
Jul 5, 2012 03:41 PM
tommyatric
Oct 19, 2011 11:46 AM
