Electrical Gurus, help... Strange
Old Nov 2, 2012 | 07:48 AM
jeffreyt's Avatar
jeffreyt
Originally Posted by fleastang
The thread title seemed appropriate so thought I would ask: My '99 7.3 has an issue where the dash lights will not come on alot of mornings, etc particularly if the truck has sat for a week or so. After a little driving it will click under the dash and they come on. No other lights have issues. I am thinking a relay somewhere. Any ideas? it only has 105,000 miles but it has the age. Additionally this morning the overhead outside temp was way low showing -1 degrees vs the actual 35 degrees and then the fuel guage went from actual 1/4 tank to showing Full. The elec gremlins were active this morning!!!
I'd look into the GEM. The click under the dash could be that. Some other reading last night lead me to that, until Tugly notified the update to VSM in my 2003.
Do the gauges and other things still work, just no lights? Are you using the automatic setting or physically turning on headlights?
Make sure the temp didn't get changed to Celsius. If it did, it wouldn't be too far from actual. Fuel, hey, if it always reads full, you never have to stop and fill up
Old Nov 2, 2012 | 07:52 AM
fleastang's Avatar
fleastang
I do not have auto headlights so they are manual. I already checked the celcius setting and it was faren. so maybe the sensor itself. All other guages are working fine except the fuel and this morning was a first for that. Gotta head to a meeting but will be checking back in and hopefully have a potential solution. Thanks thusfar!!
Old Nov 2, 2012 | 08:01 AM
jeffreyt's Avatar
jeffreyt
Well it was worth a try. I'd check the manual for a relay for the dash lights before getting into the GEM. If that's the only symptom (I'm excluding the temp and fuel because I don't know that they are controlled by the GEM) it may be something else.
To test the temp sender, I think AE gives the readout for that. If it gives bad data as well, it is likely the sender. Could be an easy fix.
Old Nov 2, 2012 | 06:28 PM
pminne's Avatar
pminne
Rocky Mountain High
Would a bad VSM cause an intermittent no-start (good crank, no smoke)???
Old Nov 2, 2012 | 06:36 PM
jeffreyt's Avatar
jeffreyt
Here is the original post about VSM. I found it in my research last night. https://www.ford-trucks.com/forums/4...-theory-3.html
I don't have a clue if the VSM controls starting, but my initial guess would be IDM or fuel pump, considering there is no smoke.
Old Nov 2, 2012 | 08:29 PM
firedewd's Avatar
firedewd
Every now and then (maybe twice a week) when I crank up the truck, the radio will not come on and windows will not go up and down. These are the only two items I have noticed not working. Usually they come on within 2 or 3 minutes, but i've figured out that if I turn the dome light on, they magically come on and start working. Doesn't work if I open the door to turn the dome on, only by rolling the dimmer switch up.
Any ideas? I'm thinking maybe it's a relay?
I had the same problem in an older Ford van. It turned out to be the ignition switch contacts. When you turn the key from ON to START, the accessories you mention get shut off while the engine is cranking. When the key is released to return to ON, it doesn't return all the way back to make good contact in the switch. If I banged on the dash then everything started working ok. I replaced it and never had another problem.
GGood Luck!
Old Nov 2, 2012 | 09:58 PM
pminne's Avatar
pminne
Rocky Mountain High
Already ruled those two items out, so moving on to other possibilities. I do have the intermittent non working windows/radio for 2-3minutes after starting, so was wondering if this is related to intermittent starting.
Old Nov 2, 2012 | 10:16 PM
Tinkerbell73's Avatar
Tinkerbell73
I am having the exact same issue as you are, especially when it's warm out. I posted on a forum (I thought this one) and I was told it's the relay that keeps the radio on after vehicle key is turned off and the radio stays on until door is opened, relay is going bad, so it's doing the opposite of what it's supposed to do. It's under the hood, on drivers side, the cluster of relays close to fire wall. I've been meaning to look into it, but have another issue I'm trying to figure out, lol!
Old Nov 3, 2012 | 05:56 AM
jeffreyt's Avatar
jeffreyt
I have never had issues with starting other than the first winter I had the truck (bad GPR). Is your intermittent starting related?
Old Nov 3, 2012 | 05:59 AM
jeffreyt's Avatar
jeffreyt
I'll look into that. The windows do the same thing (delay until the door opens), so it would make sense. I was just guessing that that would be controlled by VSM. I'll look to see if I can identify that relay...
Old Nov 4, 2012 | 09:53 AM
pminne's Avatar
pminne
Rocky Mountain High
No, the intermittent windows/radio thing only happens IF the truck starts. I was hoping some of the electrical gurus out there could comment on if they have seen VSM issues creating other problems beyond security items such as starting. I am taking it to the dealer on Monday to have the VSM replaced for the windows/radio issue. I'll comment back if it helps with the intermittent starting too.
Old Nov 4, 2012 | 10:16 AM
Calli's Avatar
Calli
I'll say this again as I am the only one that fixed problem by drying out/replacing driver's side window motor. They collect water and cause all kind of goofy issues. Radio won't turn off, radio stays on, interior lights stay on, etc. At one time had to install battery disconnects until I found out the problem and replaced window motor.
Carrie Scott
Nov 16, 2018 03:57 AM
bekko
Nov 1, 2013 02:22 AM
jasondinsmoore
Electrical Systems/Wiring
Sep 1, 2012 07:26 PM
bubbasz1
Dec 1, 2008 07:21 PM
cc_rider
Jun 19, 2008 12:06 PM
