Electrical Gurus, help... Strange
Old Nov 1, 2012 | 07:09 PM
jeffreyt's Avatar
jeffreyt
Every now and then (maybe twice a week) when I crank up the truck, the radio will not come on and windows will not go up and down. These are the only two items I have noticed not working. Usually they come on within 2 or 3 minutes, but i've figured out that if I turn the dome light on, they magically come on and start working. Doesn't work if I open the door to turn the dome on, only by rolling the dimmer switch up.
Any ideas? I'm thinking maybe it's a relay?
Old Nov 1, 2012 | 07:20 PM
joeyd61's Avatar
joeyd61
I have been chasing the same issue for 3 years...only I tap the dash above the radio and that works most of the time,other times I have to wait...
Old Nov 1, 2012 | 07:33 PM
jeffreyt's Avatar
jeffreyt
try switching the dome light on next time. I'm determined to figure it out, but it's so sparatic it's nearly impossible to trouble shoot. And, i'm not a very good electrician...
Old Nov 1, 2012 | 07:39 PM
Tugly's Avatar
Tugly
Leaky windshield? The GEM module controls that on 99-01 and the 02-03 has the VSS module that controls it. GEM is in front, where the windshield can leak on it - and the VSS is on the back-passenger side.
Old Nov 1, 2012 | 08:51 PM
jeffreyt's Avatar
jeffreyt
Thanks Tugly. I was just reading a thread about the GEM causing similar issues in the f150 section. I've got a 2003 (really need to add that to my sig one of these days). So i'll look into the VSS.
BTW, GEM=generic electronics module? VSS?
Old Nov 1, 2012 | 08:58 PM
BigAlsPSD's Avatar
BigAlsPSD
Technically it's called the VSM on later trucks.
Vehicle Security Module
Old Nov 1, 2012 | 09:07 PM
autoxtech's Avatar
autoxtech
I had the same issue and also noticed that the light did cause some things to work and other not to work. i traced it all back to fuse box. i remove the fuse box and found it rusted, prevoius owner had windshield that was installed incorrectly and water was leaking into fuse box. i never had a wet carpet it all pooled into fuse box. hope this helps. note i replaced the fuse box and put my gem module in a bag of rice while i waited for the new fusde box to come in, no problem since.
Old Nov 1, 2012 | 09:08 PM
jeffreyt's Avatar
jeffreyt
Well there's definitely something wrong with my VSM...lol
Old Nov 1, 2012 | 09:13 PM
joeyd61's Avatar
joeyd61
okay, I have checked everything, even took it to the dealer, they cant figure it out because it never does it there..The diesel tech thinks it has to do with the instrument cluster..Thats a lot of $$$ for a guess...
please if you figure this out,let me know..I know mine has to do with humidity, the more humidity the more it acts up...I keep waiting for it to stay dead
Old Nov 1, 2012 | 09:28 PM
jeffreyt's Avatar
jeffreyt
I may pull the VSM and check the grounds... It's not bothersome enough to pay for a new VSM and pay the dealer to reprogram it for me. Not yet...
Old Nov 1, 2012 | 09:50 PM
jeffreyt's Avatar
jeffreyt
Joey, I saw where you posted in this thread. Did you try changing your VSM? I'm guessing you didn't, or did and it didn't help.
https://www.ford-trucks.com/forums/4...-theory-3.html
Old Nov 1, 2012 | 09:53 PM
jeffreyt's Avatar
jeffreyt
It is supposed to be behind the radio, which would make sense why everything starts working when you tap on the dash...
Old Nov 2, 2012 | 07:11 AM
joeyd61's Avatar
joeyd61
I had the dealer to reprogram it..
Old Nov 2, 2012 | 07:20 AM
jeffreyt's Avatar
jeffreyt
Well if the hardware is damaged, a software update wouldn't fix the issue. It still could be the VSM. Mine isn't bad enough to justify replacing yet, but if yours is driving you crazy and you are worried about it, you could try replacing the VSM instead of just reprogramming it.
Old Nov 2, 2012 | 07:35 AM
fleastang's Avatar
fleastang
The thread title seemed appropriate so thought I would ask: My '99 7.3 has an issue where the dash lights will not come on alot of mornings, etc particularly if the truck has sat for a week or so. After a little driving it will click under the dash and they come on. No other lights have issues. I am thinking a relay somewhere. Any ideas? it only has 105,000 miles but it has the age. Additionally this morning the overhead outside temp was way low showing -1 degrees vs the actual 35 degrees and then the fuel guage went from actual 1/4 tank to showing Full. The elec gremlins were active this morning!!!
