Sponsored by: Real Truck
Electrical issues on our 6.0’
Old Nov 15, 2018 | 09:15 PM
Carrie Scott's Avatar
Carrie Scott
Thd radio turns off once you open the door after it’s been shut off, BUT omce you shut the door the radio turns back on while the truck is off , also the windshield wippers just up and. Stopped working , but when the radio is On and you go to turn the wipers one it shuts the radio off ..
Help !!! Wipers only go on when you bang on them
Old Nov 15, 2018 | 11:44 PM
burnthelight88's Avatar
burnthelight88
Wipers and radio delay are both symptoms of GEM module issues. You'll see there are at least 2 other front page GEM problems. Very common in these trucks. First thing to do is get up under the dash and see if you're getting moisture in the cab from a possible leak somewhere. I posted this question in another thread, but apparently these windshields are hard to seal because it seems like way too many people end up with moisture in their GEM. Do some forum searching on the GEM and you'll see what I'm talking about.
The fix if that really is the issue? Fix moisture leak first. Pull GEM and attempt drying it by leaving it in rice or something similar.
Old Nov 16, 2018 | 03:57 AM
brd7666's Avatar
brd7666
It might help if you gave the year, model, and as much information about the truck
Hesson81
Jul 22, 2019 04:03 PM
tempests
Sep 7, 2018 08:44 AM
papajoemrt
1997 - 2003 F150
Feb 11, 2010 05:15 PM
renchr56
Jan 26, 2010 06:19 AM
Badfish740
Mar 29, 2007 11:33 AM
