67 drum to disc
Old Oct 30, 2012 | 12:42 AM
troy77's Avatar
troy77
67 drum to disc
Hey guys, got a question and need some help with the answer. I've recently bought a 67 f-100 all original with no power steering, no power brakes, 4 wheel drums, straight 6 and 3 on the tree. This is my daily drive now and I'm in the process of making it a little safer and more easy to drive. I plan on doing crown Vic swap in the future when I have the time and money, until then I found a junk yard doner a 73 f-100 that I pulled the front spindles and disc brakes, power booster, lines, proportion valve, power steering pump and gear box.
Ok now for the question. For a quick install can I put the front spindles and disc brakes on for now with what I have. With out putting the proportion valve and booster? Like I said I drive it every day and down time is my problem. I will add the booster and everything else in time. Any helpful advise or critism is always a good thing. Thanks Troy
Old Oct 30, 2012 | 04:45 AM
jowilker's Avatar
jowilker
Short answer NO! You want to do a half *** job so you can hurt someone else or yourself??
John
Old Oct 30, 2012 | 10:57 AM
HIO Silver's Avatar
HIO Silver
With careful planning and at least a three-day weekend, it is very possible to do the complete conversion.
You share the road with other folks. Don't make your slight inconvenience result in compromising others' safety.
R/ HIO Silver
Old Oct 30, 2012 | 11:50 AM
troy77's Avatar
troy77
Hey thanks for a such a fast response. Believe me I know I share the road with people, that's obvious. I think maybe some people on here need to switch to decaf in the morning. The only reason I posted the question is because I owned a 77 f-100 that had front disc but didn't have a booster. Just manual brakes. My only reasoning behind doin just the brake swap at this time was safety. Believe me anything is better then 4 wheel drums and no booster. Guess I could always cut a hole in the floor and use my feet. Haha. Just kidding (calm down) I plan on doin the whole conversion at one time. I'm kinda new to this site but after reading a lot of posts I think there are a few people that like to point out negative things and not post good advise, just my opinion. I did ask for answers and sarcasm. Anyway thanks fellas
Old Oct 30, 2012 | 01:04 PM
MIKES 68 F100's Avatar
MIKES 68 F100
If you are going to do the CV switch i'd sell the disc brake set up . do a rebuild of your stock drum brakes they work just fine when in good working order and rebuild parts are cheap.
Old Oct 30, 2012 | 03:55 PM
jowilker's Avatar
jowilker
Sorry Troy, didn't mean to hurt your feelings. You asked a bad question and didn't like the answer. Pull your big boy pants up.
John
Old Oct 30, 2012 | 09:45 PM
vwfreak's Avatar
vwfreak
Hey Troy. Agreed on Mikes point. I redid my drums and they work fine. Yeah, ya gotta push 'em, but they stop the truck.
I saw you Friday driving the kids to Valley. New wheels?
We met at a stoplight at Bullard and Waddell shortly after you got the truck.
Shoot me a pm some time.
JIM
edit: At least you have an F100. Even the drums are cheap. My F250 drums are $100 each not counting labor to swap hubs and studs over.... Ouch!!
Old Oct 31, 2012 | 01:52 PM
troy77's Avatar
troy77
Hey Jim. Yes I got stuck taking the kids to school on Friday. Haha. Three teenagers in there is a tight fit and smelly, dang. Yes I picked up some new wheels, did a trade on Craigslist for them. They fit no problem but ride completely different then the stockers. Being a wider tire in the front grabs every little rut in the road. I agree with you guys about the drums, they do stop me just fine if you mash on em. I do prefer power and disc, that's why I asked about swapping the discs in the front. I think I might return all the 73 parts and just pick up the CV front end.
Old Oct 31, 2012 | 02:06 PM
troy77's Avatar
troy77
John
Oh don't worry John you didn't hurt my feelings. My big boy pants are always on. When I posted the question I was expecting a educated answer from someone that maybe had been thru the same situation or had more knowledge in this then myself. That's the point to asking questions to learn, there for I don't think there is a bad question as you put it. If I wanted a safety talk I could have asked my mom. But thanks for your opinion. I guess if only guys like you were on here there would be a lot less posts. See that's my opinion of you.
Ok enough with the pissing contest lets get back to building trucks.
Old Nov 1, 2012 | 04:15 AM
jowilker's Avatar
jowilker
U quack me up Troy.
killbill
Feb 11, 2011 10:40 PM
boo-yaa138
23
Apr 24, 2008 12:02 AM
CRETE10
Feb 20, 2008 10:02 PM
alhanson
Apr 19, 2006 12:58 PM
72stepside
Feb 11, 2003 11:15 AM
