brake light
Old Oct 31, 2012 | 10:09 AM
zakk's Avatar
zakk
brake light
Im having a problem with my driver-side brake light/blinker is works some times and not others (obviously terrible 40 year old wiring issues) so my question is where in the wire circuit would cause this problem? from the tail lights to the cab all the wiring looks just fine (thinking its under the dash somewhere. does anyone have a wire diagram?
Old Oct 31, 2012 | 10:26 AM
jpcole9702's Avatar
jpcole9702
brake light...
what year?
Old Oct 31, 2012 | 10:51 AM
zakk's Avatar
zakk
'71 sorry need to do some signature updating
Old Oct 31, 2012 | 10:55 AM
jpcole9702's Avatar
jpcole9702
Check this site out.. should get you where you need to go...
Ford Truck Technical Drawings and Schematics - Section H - Wiring Diagrams
Old Oct 31, 2012 | 11:02 AM
Freightrain's Avatar
Freightrain
Does the running light work fine? Then the socket is grounding okay.
Does the brake light work and not the TS? Vise versa? Or both?
The brake light and turn signal function from the same bulb element, thus the same wire coming from the turn signal switch. I'm guessing that might be the problem. Try this: have someone wiggle the turn signal switch around as you watch the rear tail light. Does it sometimes work? I'm thinking the contacts might be bad and thus making it work erradic.
Old Nov 1, 2012 | 04:23 AM
jowilker's Avatar
jowilker
I agree, sounds like a grounding issue. I would start at the light, clean & scrape all points of contact. Trailer wiring gets added in along the way, tape looses it's grip. Bet it's something simple.
John
billjackson5000
Dec 14, 2023 06:00 AM
KRCenter
Large Truck
Sep 12, 2021 04:51 PM
Casey245
Dec 19, 2004 02:25 PM
77hiboyboy
Electrical Systems/Wiring
May 15, 2003 09:29 AM
Katt
Feb 20, 2000 07:02 PM
