P1211 CODE?
Old Oct 26, 2012 | 11:25 AM
hydro man 17's Avatar
hydro man 17
P1211 CODE?
Hi guys. Have '01 7.3 with 160K miles. DP tuner F5 60&80E 40&60 tow & decel. AFE intake & manifold 3.5 DP to 4" Magnaflo turbo back exhaust and auto meter guages - boost, trans & EGT.
Just had the oil cooler rebuilt and new O-rings on the fuel bowl drain replaced. Driving home from the shop the engine sounded like it went into a high performance tune ( louder injector noise and power surge )after shifting into second gear - did it twice and threw a P1211 code. It cleared OK ( on AE ) and has been OK since. Could this be from air in fuel line after the fuel bowl O-ring work?
Thanks, Mike
Old Oct 28, 2012 | 10:13 PM
hydro man 17
No ideas anyone or is this just a dumb question?
Old Oct 28, 2012 | 10:27 PM
BigAlsPSD's Avatar
BigAlsPSD
Have you looked at the ICP sensor itself, you might have oil in the connector causing a biased reading, which might explain the noise as well.
Generally a P1211 can be relatively common with higher HP tunes and the hpop not being able to provide enough oil, but your tunes are relatively low and wouldn't likely cause the issue.
Old Oct 29, 2012 | 12:52 PM
hydro man 17
Thanks Al. It was only a temporary thing and has not happened since in a couple hundred miles but I was just wondering if some air in the fuel line would cause this.
Mike
sklmod95
6.4L Power Stroke Diesel
May 31, 2018 07:31 AM
will_z32
Apr 29, 2014 05:15 PM
aggiect01
Dec 12, 2013 08:13 PM
dave91gt
Oct 18, 2010 02:31 PM
DIRTY NASTY G
1983 - 2012 Ranger & B-Series
Sep 2, 2010 09:11 AM
