6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
0088 code is in limp mode
Old May 28, 2018 | 12:36 PM
sklmod95's Avatar
sklmod95
2010 f350 crewcab dually 99000 miles just bought 6 months ago while pulling my trailer lost power an went into limp mode and wont come out only code 0088 is fuel pressure rail to high also when changing my oil just prior to towing ihad my oil pan over flow which should have been big enough for 16qts of oil. it wasfull and running out the spout all over driveway seemed like 20 qts of fluid oil change was about 6000 miles
Old May 28, 2018 | 02:50 PM
brandonrr's Avatar
brandonrr
Sounds like your HPFP (high pressure fuel pump) isn't happy. Have you changed the fuel filters yet? Hopefully you can get lucky and that fixes it. If you see metal shavings in the filters, bad news. The alternative is HPFP going out and your wallet will suffer. It is a cab-off job and will set you back anywhere from $3,000-10,000, depending on if any metal shavings have been circulated. This would require the whole fuel system to be replaced, including the injectors. If no metal shavings, you might be able to get by with only replacing the pump, which is still cab-off. Unfortunately, it sounds like you may have gotten some contaminated fuel, which can cause fuel system failure.
as for the oil "growing," you have fuel dilution. It is likely related to your HPFP problem. If you get lucky and it's just bad fuel filters, there's a few places fuel can getting into your oil. During regen, some of the unburned fuel seeps past the piston rings. If you have an issue with your DPF (diesel particulate filter) it can cause excessive regens and fuel dilution. The fuel cooler, injectors and/or HPFP are also prone to leaking fuel directly into the oil. If you can resolve the P0088 problem without surgery, I'd recommend shortening your oil change interval until you figure out the source of the fuel dilution. The valvetrain will wear out much faster with diluted oil.
Old May 28, 2018 | 07:09 PM
senix's Avatar
senix
P0088 is usually set because the VCV can no longer control the fuel pressure as required. The fix is a new HPFP. The VCV is built into the HPFP.
As far as oil growth is concerned, you have a truck that goes into regen periodically and this can cause grow if the motor is not being worked or is shut down during this cleaning cycle.
The fix is knowing when you are regening so as not to shut it down Also move your oil changes to 5K max and that will help as well.
Old May 31, 2018 | 07:31 AM
speakerfritz's Avatar
speakerfritz
have you checked the coolant in the fuel cooler resivior?
A/Ox4
17
Oct 14, 2011 11:51 AM
EddieEX10
Mar 8, 2010 08:04 PM
jakemb
Feb 7, 2005 06:48 AM
1FASTZ
Apr 1, 2004 07:58 AM
