e4od transmission problems
Old Oct 25, 2012 | 01:17 PM
JimmyO1331's Avatar
JimmyO1331
I have a 1991 bronco with a 351w and the e4od trans.. The transmission is shifting late and hard and sometimes when i let off of the gas to slow down it shifts between gears up and down by itself... The only lights on the dash that are on is the Rear Anti-lock brake light and the speedometer is not working either.. Any ideas on where to start the trouble shooting to fix it? Thanks
Old Oct 25, 2012 | 02:14 PM
Lazy K's Avatar
Lazy K
Fuel Injection Technical Library » How To Run a Self-Test Here is a link on how to get any trouble codes (even if no light on). Do that first, I would think.
Could also buy equus3145 code reader for around $25.00 to make life easier.
Old Oct 25, 2012 | 04:51 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The trans won't shift right if the speedometer isn't working OR if the ABS light is on. Most likely your vehicle speed sensor is bad.
Old Oct 26, 2012 | 12:09 PM
Lazy K's Avatar
Lazy K
Speedo is cable driven so possibly a cable problem for speedo rather than VSS. Trouble codes may tell.
IDIDieselJohn
18
Jan 5, 2016 09:02 PM
kdennie1334
Jul 4, 2014 08:55 PM
buscherautollc
16
Dec 15, 2012 03:38 PM
okiediesel
Jan 27, 2008 03:53 PM
mustangman
May 5, 2005 02:33 PM
