BTS Transmission Question
Old Oct 27, 2012 | 08:33 PM
wingnut9119's Avatar
wingnut9119
I am in the process of installing my new BTS transmission in my 2000 7.3 Excursion and I have a question. This being late on a Saturday night I don't have the option of calling Brian at BTS so I thought I would ask here. The transmission shipped with plastic plugs in the cooler bypass fittings. When I removed the plug nearest the front of the transmission a little yellow o-ring came out with it. When I went to put the o-ring back in the fitting I noticed a bunch of what looks like vasoline or some other type of grease in the fitting. I stuck the tip of a small screw driver into the fitting and it is completely packed with this "grease". Does anyone know why all this grease would be in that fitting? Should I clean it out before I put the line on? I checked the other fitting near the rear of the tranny and it is clear, no grease there.
Thanks for any info,
Chip
Old Oct 27, 2012 | 09:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Leave the grease. When the ATF hits it, it will dissolve. It's there to hold things in place like the o-ring.
Old Oct 28, 2012 | 08:02 AM
wingnut9119
Mark,
Thank you for the quick reply. I thought that may be the case, but it just seemed like a lot of it in there.
Thanks again,
Chip
Plain Jane
Mar 7, 2012 01:27 PM
vze2sgxa
Jul 12, 2009 12:42 PM
vze2sgxa
1997 - 2003 F150
Jul 12, 2009 10:30 AM
mtcox
May 27, 2006 08:11 AM
okst1
Dec 7, 2005 10:14 PM
