e4od downshift HELP!
Old Jan 25, 2008 | 01:34 AM
okiediesel's Avatar
okiediesel
I've got a 91 f250 4x4 with e4od that was rebuilt about a year ago. It also has had a US Gear dual range auxilary trans installed. I bought it about 3 months ago. It drove great at first then the speedo started acting up. Then it started shifting spasticaly. I took it to a friend that has a trans shop. He pulled codes and told me to replace tach sensor. I replaced it to no change except a few days later the speedo stopped working all together. I replaced speed sensor wich is in line with speedo cable. No speedo. Replaced worn out drive and driven gear on the end of the speedo cable. Speedo works. But on the 4-3 downshift it doesn't shift back to 3 untill you give it gas then it jerks. My friend said to replace the valves in the accumulator. Replaced valves still have the same downshift problem. Next he tould me that it could be the check ***** in the main valve body. Haven't done this yet. Have anyone ever heard of these check ***** wearing down or breaking? Any help would be great.
Old Jan 25, 2008 | 04:24 AM
phil6608's Avatar
phil6608
Iv never heard of check ***** wearing out or breaking but I have heard of them getting stuck and not operating properly.
Old Jan 25, 2008 | 03:29 PM
okiediesel's Avatar
okiediesel
He said that they wear down in diameter or get flat spots on them. They are made of hard rubber.
Old Jan 25, 2008 | 03:31 PM
95F350XL's Avatar
95F350XL
When I did the shift kit in my E4OD, the ck ***** are metal. There was 1 plastic one.
Old Jan 25, 2008 | 03:49 PM
phil6608's Avatar
phil6608
I thought they were all metal but Iv been wrong before...lol
Old Jan 26, 2008 | 04:15 PM
cowchasinsix's Avatar
cowchasinsix
These E4ODs are funny critters. Have you tried disconnecting the battery overnight, which allows the computer to reset? It may be a bit of a long shot but after it was acting up I don't think it could hurt anything. Let the thing relearn everything. Best thing I can think of if the weird shifting and speedo fix happened at the same time.
Good luck.
Old Jan 26, 2008 | 05:43 PM
Towmanjbo's Avatar
Towmanjbo
Have you updated the part thing by the shift lever on the tranny? This tells the tranny when to shift. It is external right on the shifter linkage. Might not have been done when the tranny was rebuilt because it is external. Ford makes an update kit for it, just a new plug that retrofits the old plug and new part. I forget what it's called but someone here should be able what it's called this is where I found out about it.
Old Jan 27, 2008 | 12:15 AM
okiediesel's Avatar
okiediesel
It seems to be shifting fine every other time except on the 4-3. Like if I'm driving about 40ish start to slow down for a stop light to about 25 then the light turns green I go to give it gas, it briefly freewheels then kicks in kind of hard. Would that shift indicater thing cause anything like that?
Old Jan 27, 2008 | 04:06 AM
Towmanjbo's Avatar
Towmanjbo
Ya my Bronco was shifting strange for awhile I did this upgrade and it fixed it.
Old Jan 27, 2008 | 01:01 PM
cowchasinsix
With that last description I will change my vote to MLPS. Here's the link when one we have went bad in a '94 Bronco.
https://www.ford-trucks.com/forums/6...wn-switch.html
Old Jan 27, 2008 | 01:20 PM
mhg's Avatar
mhg
www.fordfuelinjection.com
they have a write up on the MLPS
and how to test it
look in the down load files
Old Jan 27, 2008 | 03:53 PM
66F100Again's Avatar
66F100Again
you didn't mention -- but did you check for any error codes stored in the engine control module?
71buickfreak
Jul 22, 2019 09:58 PM
3000gtman
45
Oct 21, 2016 08:57 AM
slashfan7964
Apr 3, 2016 08:40 PM
Truxx1956
26
Jul 1, 2014 03:53 PM
screaminford
Jan 24, 2011 09:29 AM
