highways stutters
Old Nov 3, 2012 | 11:33 AM
broncxl302's Avatar
broncxl302
is under 500 psi bad at idle? dont you need that to even start?
Old Nov 4, 2012 | 10:18 AM
broncxl302's Avatar
broncxl302
got some numbers. all these are when hot and on stock mode
highest number when it started that i saw was 1500.
idle between 450 and 500 jumps all over the place onlce saw it at 500 for a secound.
my girl friend was reading the number and when we started to move to get onto the road (normal acceleration) she siad she saw it drop down to 435.
on the road wot hightest it got was 2488 she siad it help it there for the most part. so thats what i got on that.
should the numbers be jumping all over the place like crazy?
Old Nov 4, 2012 | 01:48 PM
2000ca250's Avatar
2000ca250
450-500 seems a little low at Idle. You should definitely fill out your Sig so that we can see what Mods you have done. If you have stock injectors I would talk to your tuner about bringing ICP up at idle possibly, but its not going to cause the studder.
What has me interested in you saying ICP dropped down to 435 as you put it in gear and started to accelerate. That is not necessarily a bad thing, but it shouldnt happen. Also what were the duty cycle numbers. 2488 at 20-30% DC wouldnt be that bad, however 2488 at 40-50% DC would indicate a problem with the pump.
Post up what your mods are, who does your tuning, and what your DC% is at idle, at WOT, and just cruising down the road.
Old Nov 4, 2012 | 03:15 PM
broncxl302's Avatar
broncxl302
i know my idle % is 11
ill test my wot and cruise tomorow
i did all my test on stock should i do it on all settings?
Old Nov 4, 2012 | 03:55 PM
2000ca250's Avatar
2000ca250
Do it on whatever setting your issue happens most frequently on
Krochus
15
Jun 3, 2013 07:39 AM
mudmaker
Aug 7, 2012 07:55 AM
Tugly
15
Apr 12, 2012 09:28 AM
RAGaz
Modular V10 (6.8l)
Jul 13, 2010 10:48 AM
BitBanger
Apr 24, 2008 12:46 PM
