4r100 rebuild
Old Oct 23, 2012 | 02:45 PM
Scuster132's Avatar
Scuster132
4r100 rebuild
I'm in the processs of disassembling my transmission from a 2001 f250 powerstroke cause the mechanical diode blew up and I can't get thhe front pump to budge I threaded two slide hammers into the two holes with threads all the way down but will not even budge. The filter is out and I just can't see what else could be holding it. It seems like it just slides right out for ever one and I've got 5lb hammers on it and it won't move if any one has any ideas it would be greatly appreciated
Old Oct 23, 2012 | 03:24 PM
jk080's Avatar
jk080
Transmission Rebuilder
Maybe the slide hammer is threaded into the case threads as well?
Try - Pull the input shaft about half way out and lightly hit it with a rubber mallet from side to side to work the pump loose. I can get just about all of these pumps out like that.
Old Oct 23, 2012 | 03:33 PM
Scuster132's Avatar
Scuster132
I thought that might be the problem so I only threaded it in a couple turns but ill try putting the shaft back in and working it around its my first transmission so I'm sure ill have more questions but thank you for your quick response
Old Oct 24, 2012 | 12:53 AM
Scuster132's Avatar
Scuster132
Trans is all taken apart I was being dumb and used the pump bolts to figure out what size bolts to use for the slide hammer adapters so I was pulling on the case not the pump as soon as I used the right ones pump came right out everything else went really smooth
Old Nov 11, 2012 | 04:00 PM
Scuster132's Avatar
Scuster132
Got the trans back in today but all I have is forward gears neutral park and reverse are all forward gears I was just wondering if anyone knew what the problem is my guess the manual lever position sensor wrong solenoid pack or I got a check ball in the wrong spot
Old Nov 11, 2012 | 07:51 PM
jk080's Avatar
jk080
Sounds like you missed the manual valve on the valve body.
Name:  Manual Valve.JPG
Old Nov 12, 2012 | 02:54 PM
Scuster132's Avatar
Scuster132
Thanks I did have that hooked up wrong so I fixed that problem but may have caused another
Now I have no reverse and seems to slip and not want to move in forward gears I think it might have something to do with line pressure since it takes more pressure to operate reverse hoping I used the wrong gasket or have a check ball in the wrong place really hope the valve in the pump isn't sticking so I don't have to pull the transmission again I can't seem to find a pressure gauge instock anywhere so I'm gonna order one tonight
Old Nov 12, 2012 | 05:56 PM
Scuster132's Avatar
Scuster132
I dropped the pan and valve body seems like all check ***** are in the right spot air checks were good so all that's left is wrong gasket or stuck valve in the pump that's all I can think of anyone else have any ideas
Old Nov 12, 2012 | 06:27 PM
jk080's Avatar
jk080
Checking the line pressure or removing a cooler line to see if the pump is even working would help to decide whether or not to pull it back out. I don't see many stuck PR valves in this transmission.
Old Nov 12, 2012 | 10:45 PM
Scuster132's Avatar
Scuster132
ill try disconnecting a cooler line in the morning i put new pump gears in it .427 line valve in accumulator body superior shift kit two the plastic valve in the stator two other valves in the pump cant remember what their called offhand the pump is actually the only part i had a tranny guy rebuild so i kinda doubt he did it wrong
he lent me a tool to measure the end play to make sure all the clutches were seated and i triple checked that the tourque converter was seated into the pump just this is just a project for somethin to do while laid off so i dont really have any money to just bring it into the shop so thanks for all your help man
Old Nov 14, 2012 | 04:45 PM
Scuster132's Avatar
Scuster132
So I pulled the cooler line and no fluid is moving through it so I guess trans has to come out again ill be pulling it tomorrow so if you have any other ideas please stop me
Old Nov 14, 2012 | 04:50 PM
Skip1970's Avatar
Skip1970
good luck, im just here for moral support! U CAN DO IT!!!
Old Nov 14, 2012 | 04:58 PM
Scuster132's Avatar
Scuster132
I talked to my trans guy he said most likely the torque converter wasn't seated properly and striped the splines of the pump
Old Nov 15, 2012 | 03:18 PM
Scuster132's Avatar
Scuster132
I used an air compressor gauge as a line pressure gauge which I think should be ok I the pressure is bouncing between 15-25 psi if I shift into reverse it drops off to zero so I don't think I could've striped the pump cause I wouldn't have any pressure right?
Old Nov 15, 2012 | 04:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Take the trans out. It's broken.
As to what's wrong, it is academic now. SOMETHING is broken and it isn't going to get fixed in the truck. With zero pressure in reverse something mechanical is wrong. 15-25 PSI also shows that there is a big problem.
Striping splines never hurts unless you use too much paint to make the stripes. Stripping the splines is a BIG no-no.
