6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
I know.....
Old Oct 23, 2012 | 02:38 PM
RM2738's Avatar
RM2738
I know.....
I'm going to probably catch some flack from you guys but I've been running some tests over the past few months and I've noticed I've gotten better mileage when adding 32oz of two stroke to my diesel than adding the appropriate amount of DK.
Old Oct 23, 2012 | 04:50 PM
slowmans's Avatar
slowmans
I run 2 stroke in the winter, then when it gets warmer I run Biodiesel.
Old Oct 23, 2012 | 05:34 PM
UGA33's Avatar
UGA33
The Duramax (01) and Cummins (03) were both common rail injected trucks back when we still had a national high sulfur fuel supply and they did fine. Dont see why it would hurt these fuel systems to run a little 2-stroke.
Old Oct 23, 2012 | 06:27 PM
RM2738's Avatar
RM2738
The only concern I would have was if my DPF was still installed, but deleted I don't see any issues. I will still run DK every few tanks, but the 2 stroke seems to give me better results.
Old Oct 23, 2012 | 06:31 PM
Ding126's Avatar
Ding126
32oz per tank? How big of a fuel tank do you have. If I added 16 oz per tank, would that benefit the truck...I've only added DK.
I would like more info and opinions.
Thanks,
Mike
Old Oct 23, 2012 | 06:33 PM
Ding126's Avatar
Ding126
My motor is bone stock..is this a no go?
Old Oct 23, 2012 | 06:37 PM
slowmans's Avatar
slowmans
Im not sure I would run it in my truck if I was still stock, but then again it is an ashless oil so I cant believe that it would hurt? The recomended ammount is 1oz per gallon, so if your full add 30oz then every time you get fuel add 1 oz per gallon of fuel you pump.
Old Oct 23, 2012 | 06:41 PM
RM2738's Avatar
RM2738
Thanks,
Mike
30.5 Gallons.
I've heard as much as a quart in 24 gallons. Wouldn't ever go that high. Last month I ran marine grade two stroke and seemed to get a hair more water out of my fuel water seperator. Possibly a coincidence, but considering a good marine grade 2 stroke tends to have (more) demulsifiers and I almost always buy diesel from the same high volume station, I feel it helped.
Old Oct 23, 2012 | 06:58 PM
slowmans's Avatar
slowmans
are you running the supertech TCW3?
Old Oct 23, 2012 | 07:08 PM
RM2738's Avatar
RM2738
Yup. Ole Walmart brand.
Old Oct 24, 2012 | 06:09 AM
wp6529's Avatar
wp6529
So you're adding an additional 1/4 gallon of fuel to the tank, are you adding that to your MPG calculations? That fuel alone would be expected to add about 3.5 miles of travel to the tank.
Old Oct 25, 2012 | 02:07 PM
RM2738's Avatar
RM2738
I did. Regardless, if I did or not, I ran the same 300 mile trip last month twice. First with DK, then ran a tank without an additive, then on the second trip, I added 32 oz supertech outboard ashless and hand calculate 0.75 more miles per gallon which on a 30.5 gallon tank yields 22.8 more miles per tank.
Mikey Oldaker
22
Dec 2, 2012 01:18 PM
jleal_21
36
Jun 26, 2012 07:34 PM
REELNAUTI4U
Jun 1, 2007 02:39 PM
kovacik76
Apr 27, 2007 06:49 AM
Daryl Hunter
Nov 19, 2004 01:10 PM
