PRI-D Fuel Additive?
Old Nov 18, 2004 | 01:15 PM
Daryl Hunter's Avatar
Daryl Hunter
A friend told me about PRI-D fuel additive last night. Has anyone heard about or used this stuff?
Mostly I've heard guys talking about Stanidyne (sp?) or PowerService.
Old Nov 18, 2004 | 02:27 PM
jackofalltrades's Avatar
jackofalltrades
Diesel additives
Darylhunter, (as a diesel newbe, can I impose upon your thread?), Before someone adds their $.02 about PRI-D, I've heard about the other additives too, but may I also ask, 'when do we need to add fuel conditioners'? OK, I didn't crawl from under my rock just yesterday, I know that Diesel can gell at cold temps, but at what temperatures should we be concerned?
Old Nov 18, 2004 | 03:33 PM
Daryl Hunter
My understanding of these additives is that they should ideally be used regularly even during the summer. Their principal purpose isn't to prevent gelling - at least I don't think that's the case.
Old Nov 18, 2004 | 05:07 PM
SBV45's Avatar
SBV45
I use it for the added lubricity and fuel conditioning it might provide. I have the early 03 C94 injectors and want to hedge my bet. I does seem to run better, quieter and get better fuel economy. Not much, but enough to be noticeable.
Old Nov 18, 2004 | 07:39 PM
jimmy-six's Avatar
jimmy-six
I use Stanadyne in each tankful...I do it because of the good ratings it recieved here on this site and my turck is parked sometimes for weeks at a time..I made good sense to use something...Good Luck
Old Nov 19, 2004 | 06:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I am with you on that one buddy
Old Nov 19, 2004 | 09:06 AM
utahtom's Avatar
utahtom
I too use an additive on every tank- Power Service. The truck doesn't seem to put out nearly as much smoke on start-up nor under hard acceleration. I do not have any info on the PRI-D, although I am curious if anyone has used the Lucas Fuel Conditioner?
Old Nov 19, 2004 | 09:11 AM
Daryl Hunter
But has anyone used PRI-D? Or have feedback about it?
Old Nov 19, 2004 | 11:23 AM
IB Tim's Avatar
IB Tim
I knew Darly was going to get back to his question...sorry buddy never even heard of it.
Old Nov 19, 2004 | 01:10 PM
Jim Diesel's Avatar
Jim Diesel
I've been using PRI-G for 5 years, and Pri-D since I bought the 6.0, about 1 year. You will probably not "feel" anything different, it is just a fuel preservative/restorer, and helps keep the cylinders from building up carbon deposits. They also make a biocide, Pri-Ocide, and anti-gel, Pri-Flow, of which I also use both.
http://www.priproducts.com
