HELP! Vacuum line issues?
Old Oct 22, 2012 | 08:16 PM
martinkjc's Avatar
martinkjc
Exclamation HELP! Vacuum line issues?
Hey guys. I have a 06 f350 6.0L Diesel
I am having trouble locating my issue. My heat is only blowing from the defrost vents and floor vents. I have checked my lines around the resevoir, going to the pump, checked the pump as well, mostly all the lines going under the car i think(a diagram would be great) even replaced a line going to the hub. I checked the #24 and #27 fuses. Any other suggestions? Thanks
Old Oct 22, 2012 | 08:34 PM
Yahiko's Avatar
Yahiko
If you have heat going to the floor then you may have a door problem.
As I understand it the default is the defrost not the floor. The easy to
check is with a vacuum gauge and see if it holds or not.
Sean
Old Oct 22, 2012 | 09:19 PM
Yahiko's Avatar
Yahiko
Here you go I did some digging for you.
Sean
Old Oct 22, 2012 | 10:12 PM
martinkjc's Avatar
martinkjc
Sean
Thanks a tonne i figured out that the problem is the 4x4 solenoid. Now the concern I have with this is that I just got that solenoid just replaced.....
Old Oct 22, 2012 | 10:13 PM
Roasted7's Avatar
Roasted7
Just this past weekend I discovered a vacuum leak in the control valve for the auto locking hubs. I just plugged off that line until I can get a new control valve.
Old Oct 22, 2012 | 10:22 PM
martinkjc's Avatar
martinkjc
Where is that located? are you talking about the 4x4 solenoid?
Old Oct 23, 2012 | 02:23 AM
Yahiko's Avatar
Yahiko
The 4x4 solenoid is on passenger side engine compartment
near to the vacuum pump on side. Look at the pump and then
look back towards the heater fan you should see it there.
It could just have a bad line.
Sean
Old Oct 23, 2012 | 08:01 AM
Roasted7's Avatar
Roasted7
Mine is mounted right on the fender right behind the vacuum reservoir.
Old Oct 23, 2012 | 10:48 PM
martinkjc's Avatar
martinkjc
is the control valve the same thing as the 4x4 solenoid was my question
Old Oct 24, 2012 | 07:58 AM
Roasted7's Avatar
Roasted7
Yes. I just didn't know exactly what to call it.
Old Oct 24, 2012 | 03:10 PM
Yahiko's Avatar
Yahiko
I have a name for you
4X4 control solenoid valve.
OR the Thingamajigger.
Sean
Roger T. Pipe
Jul 13, 2019 08:56 AM
Dennischim
13
Jun 29, 2019 09:17 PM
hadam
Sep 14, 2015 03:09 PM
wintertruck87
28
Nov 21, 2014 10:34 AM
gr8scott72
Nov 15, 2008 12:14 AM
