Servicing the Tranny -- Question
Old Aug 22, 2007 | 06:36 PM
azfordf100man's Avatar
azfordf100man
Well my f100 has a c6 3spd auto and I'm probably going to service it myself. I was wondering how much fluid does this hold?
Also any tips? I'm going to drop the pan change the filter and refill it, anything else?
Thanks,
Mike
Old Aug 22, 2007 | 08:53 PM
BobbyFord's Avatar
BobbyFord
Drain the converter, also. With the converter empty and the pan empty should hold between 11-12 quarts.
You might as well adjust the second gear band while you're under there. On the driver's side of the trans, near the linkage there is a hex nut with a square-headed stud sticking out of it. Hold the square-headed bolt from turning and loosen the hex nut that is locking it down. Back the hex nut off a turn ir two, next tighten the square-headed bolt to 10 ft. lbs. then back the square-headed bolt out 1-1/4 to 1-1/2 turns. Hold the square-headed bolt from turning and lock down the hex nut.
Old Aug 25, 2007 | 12:01 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Wish ya luck on the filter change as untorquing the filter unloads the pressure between the shifter body and the seperator plate with a gasket between. This gasket at one pressure port is 3/16" or less wide and can blow out in the future causing a slow tranny failure. Been known to happen hence a dab of contact cement during tranny assembly helps. Drop a flat magnet in the pan for them iron particles as that coarse filter can not collect them.
On the band adjustment that locknut is a once used throw away item as it has sealing material on the face. To reuse you will cause a very small leak, any leak is not good and ATF will find it.
On fluid your talking 12 3/4 quarts.
Bang the pan flange bolt holes flat before installing, another leak prone area and do not over torque your pan bolts.
Old Aug 25, 2007 | 09:30 AM
DarkWolf40's Avatar
DarkWolf40
I've heard you should only put about 4 quarts in, start engine for just a few seconds then put the rest of the fluid in.
Old Aug 25, 2007 | 03:43 PM
blue68f100's Avatar
blue68f100
If you do not drain the converter 3-4 qts is a good starting point.
Old Aug 25, 2007 | 09:33 PM
galaxie641's Avatar
galaxie641
Great timing I am planning on doing the exact same thing to my C6.
Old Aug 26, 2007 | 08:54 AM
blue68f100's Avatar
blue68f100
It always better to drain the convert if you can. It hold most of the trans fluids. There is a 1/8" pipe plug in most C6. You may need to rotate the crank to locate it. The flywheel should have a hole for access.
38packard
Dec 13, 2013 01:02 PM
Jasonnoel
Oct 14, 2013 08:07 PM
Ajlowry
May 28, 2013 02:03 PM
azfordf100man
1983 - 2012 Ranger & B-Series
Mar 21, 2010 01:34 AM
