79 Bronco backfiring after carb and Intake change, Please advise!
I have a 79 Ford Bronco 400 T18, that is back firing out the carb and exhaust and bucking only under a load. Here is what I did. About two months ago I drove out to my buddy’s with no trouble, Took off the factory intake and carb. Swapped on a Edelbrock intake and a rebuilt Holly carb(600cfm),with Felpro valley pan. Did it with out removing the distributor. Idles great, revs out nice. Took it for a test drive starts bucking and backfiring. But not to bad. Put the air cleaner on for the drive home made it 100 times worse. Took air cleaner of has not been back on yet. Seamed to run butter when cool. Started to look for the problem. Adjusted the floats that helped some, but the more I drove it the worse it got. Found the advance was not working, changed the advance, retimed the engine for the 1st time with 4bbl. Switched the vacuum advance from the carb to the manifold and back to the carb. No help. Found that the vacuum port on the metering block was not working at all. Got another rebuilt Holly 600cfm carb, swapped it on NO CHANGE! Got the starting fluid out. Found a leak on the intake manifold, so I pulled it new Felpro valley pan Black RTV around every port both sides of the valley pan. Still no change! Just this week I did a compression test 5 cylinders with 110psi 2 with 115psi and one at 120psi. Plugs all light golden brown. Found the Accel coil was leaking oil replaced with house brand coil, found the plastic in back of the ICM was loose, test good at 1st. Tapped it while testing and it failed every time after that! Replaced with new. Still no change! So right now She will start with just a turn of the key Idle like a dream, Drives nice tell it warms up then Right back to backfiring and bucking. I have found if I drive in a lower gear at a higher RPM its better but still not right.
Sorry for the long story, I tried not to leave any detail out that might help.
Im out of Ideas any thought would be of great help! Please and Thank You!
you sure you dont have plug wires crossed? they might be crossfiring too, check it.
As simple as it is, check your distributor cap.. sounds like it could be it, really.
Even if you didn't touch it, you think you possibly leaned on it while working on the carb and cracked it? I just did this a few months ago and didn't realize i had busted it. My Bronco ran terrible when warm, so I remembered leaning on it, figured I had broke it, replaced it and it fixed the problem.
Hmm interesting story. Is it the edelbrock performer 400 intake? I have that and a carter fab 4bbl now on my 78 and save for the entire exhaust being one big leak, it runs fine.
one thing to think about, maybe you need a spacer. the heat from the block could be transferring into the carb and causing it to burp. I haven't had that issue but it could be a possibility. Next make sure the carb is tuned right, choke is working, all that good stuff. Hmm I know there are other things but I can't think of them at the moment.
lindb40530
18
01-31-2017 10:15 AM
cfordmanh68
35
05-12-2013 01:51 PM
LastStarfighter
12-22-2007 11:39 AM
walt80
11-29-2003 08:04 PM
78bigunns
01-01-2003 11:33 PM
