1978 - 1996 Big Bronco
Bronco will not start
Old Oct 27, 2012 | 07:09 PM
davegr1's Avatar
davegr1
My son has a 1993 Bronco , 5.8. It died today, the motor will turn over, but not start. I thought it was the fuel pump, I did the mod to access the pump, removed the cover and pinned it for power. If I force the relay closed the pump runs fine. Still will not start with the relay closed manually. I checked for spark, no spark either. It seems the fuel pump relay is not closing, and I get no spark, (i slaved in a new coil to try it, no luck) I have power at the relay socket (fuel), but it will not cycle. When we tried to short the coil lead, no spark while turning it over, It sparks once when you release the key from start. (it does this everytime) . Any Ideas...
Old Oct 27, 2012 | 07:50 PM
khadma's Avatar
khadma
Carpenter Local 745
Check engine light on?
If so check for codes.
Check for relay to PCM/ECM.
Check that ground wires are secure.
Make sure battery/ terminals and charging system are good.
Check inertia switch.
Need to check for fuel pressure at the rail.
Old Oct 28, 2012 | 04:36 AM
davegr1's Avatar
davegr1
I checked the inertia switch, it was good.
There is no fuel pressure in the rail. , but that goes along with the pump not running,
I did not ck the PCM Relay . Do you know which relay. ( I know which one is for the Fuel) Also been reading about the PCM in these years burning up. Any one else have this type of condition?
Also, did not ck for codes, I do not have a scanner. but I might have to get one.
Old Oct 28, 2012 | 12:30 PM
davegr1's Avatar
davegr1
Update, when I tried to get the codes, I shorted the cel connector as required and the fuel pump started working. It still will not start, but the pump runs all the time now. I did disconnect the spout connector and truck tried to start. hook it back up and we get no spark still. Going to try a TFI.
Old Oct 28, 2012 | 01:07 PM
Edgethis's Avatar
Edgethis
So the pump runs now when you turn the key? Have you checked to see if you have pressure at the rail now?
WBBulldogs
1997 - 2003 F150
Mar 4, 2013 07:25 PM
DBANDGB
Feb 27, 2010 03:18 PM
dozer66
Nov 29, 2008 08:43 AM
timbarr
Aug 4, 2003 07:55 PM
tim_1911
Nov 19, 2001 11:46 AM
