Bronco II Ford Bronco II
window fix
Old Oct 21, 2012 | 04:30 PM
rusty7983's Avatar
rusty7983
window fix
My windows did not roll up, Yes to down, but sucks if it rains. I have looked and googled and talked to every gearhead I know. 1 guy uses ball bearings. 1 guy said he uses 5/16 nuts. I was going to, but needed to both windows and only had 2 nuts. I googled and found a explorer writeup where he used 3/8 rod. I did the same. It is the same size (or close) as the plastic pieces. I had some 3/8 tubing from a harley build. It works great. I also drilled holes in the door and unbolted the motor. I didn't have to remove the regulator. Help also makes the plastic pieces. Autozone is quick to take your money and sell you a 20 gear. The help was 1/2 that much. I think the part # is 74410.
paker
1997 - 2003 F150
Mar 25, 2019 08:11 AM
90paul250
Jun 10, 2018 02:55 PM
Nickthebulldog
Jan 12, 2010 11:02 PM
phaseed
Nov 5, 2005 10:07 AM
my93
Jun 7, 2004 10:48 PM
