Sponsored by: Real Truck
Looking for some guidance
Old Oct 20, 2012 | 09:02 PM
JAllegar's Avatar
JAllegar
Hello! And Good Evening All...
Looking for some input. Noticed a few months back, while out driving - attempted to use Cruise control out on the highway and it didn't activate/turn on.
A few weeks ago - I have noticed that the airbag warning light has begun flashing occasionally; and sometimes will stay lit. It seems to be flashing a 1 5 code. Any suggestions? And or direction to head in?
Old Oct 21, 2012 | 06:39 PM
windrider127's Avatar
windrider127
Clock spring, under the steering wheel. Usually the culprit, but no details on your truck, so hard to say for sure.
Old Oct 21, 2012 | 07:42 PM
JAllegar's Avatar
JAllegar
Sorry Wind - Its a 1999 F350 CC LB 7.3 PSD 67K miles
Old Oct 21, 2012 | 08:50 PM
redford's Avatar
redford
FTE Leadership Emeritus
I agree with the clock spring diagnosis.
Old Oct 23, 2012 | 08:51 PM
mototrig's Avatar
mototrig
Newbie here! I had a similar problem on an '02 7.3 4x4 I picked up last week. No cruise control, air bag light on and no horn. I replaced the clock spring behind the steering wheel and it fixed the air bag light and horn. The replacement was straight foreward and simple with a Chilton manual. My cruise control is still not functioning though. Next step is replacing the brake relay on the master cylinder. A lot of intelligent minds on FTE point to this as a culprit. Good luck
Old Oct 24, 2012 | 06:26 PM
JAllegar's Avatar
JAllegar
Thank you all for the responses. Will look into the clock spring.
Now need to find out why the "miles to empty" stopped working in the message center. MPG/Compass/Temp guage still works though.
JAllegar's Avatar
JAllegar
Also - Horn is still working. Think it's still the clock spring?
Old Oct 24, 2012 | 06:34 PM
mototrig's Avatar
mototrig
If I remember correctly there were multiple wires in the clock spring. If it is the clock is spring going bad, you may have only severed the cruise control and air bag wires so far. I doubt it would sever all at once. Just my $.02
Old Nov 14, 2012 | 12:41 PM
mototrig's Avatar
mototrig
Did you ever figure out the problem??
DALEDIESEL
Oct 25, 2020 08:43 PM
Nickw23
Jul 12, 2018 11:10 PM
gbrown31
Feb 18, 2014 01:17 AM
kelwar
Mar 30, 2009 11:21 PM
kellyb
1978 - 1996 Big Bronco
Jan 30, 2002 08:54 PM
