TPS REPLACEMENT 1993 5.8 Windsor
Old 10-20-2012, 04:28 PM
The Storm's Avatar
The Storm
The Storm is offline
Any special procedures for accomplishing this feat??
Old 10-20-2012, 05:40 PM
95e150CW's Avatar
95e150CW
95e150CW is offline
Nope. I did mine from the front, removed the air cleaner housing and the air cleaner hoses. Wasnt too hard.
Old 10-20-2012, 06:03 PM
The Storm's Avatar
The Storm
TPS r&r
Had the throttle body off. When I put the new TPS on the plates were closed. Had to turn the TPS slightly to line up the screw holes after getting in the position to slip onto the throttle shaft. Now I've got extra high idle speed. What's up with that??
Old 10-23-2012, 06:22 PM
jimbbski's Avatar
jimbbski
jimbbski is offline
Where did you get the TPS sensor?
Try slotting the mounting holes on the TPS so that it doesn't hold the throttle open.
This is a common mod on 5.0L Mustangs to get peak performance. But what we are trying to do here is not quite the same as your problem but it should fix yours.
Old 10-23-2012, 07:23 PM
The Storm's Avatar
The Storm
The TPS isn't holding the throttle open at all. Had to rotate the TPS ccw enough to slip onto the throttle shaft tab so it would it would mate up to the bottom of the casting. Then I turned it back cw to line up the mounting screws. I think doing that got the sensor into it "range" telling the PCM the throttle is partially open.
xc4jokestomper
08-28-2010 12:55 PM
drunkenrich
06-11-2010 10:45 AM
Dales F-350
1999 to 2016 Super Duty
01-02-2010 09:34 AM
gdoggy
1983 - 2012 Ranger & B-Series
06-19-2003 09:48 PM
chuckles738
02-03-2003 03:11 PM
Quick Reply: TPS REPLACEMENT 1993 5.8 Windsor
