adjusting throttle possiton sensor
Old Jun 11, 2010 | 09:28 AM
drunkenrich's Avatar
drunkenrich
I put a new TPS on my 93 f250 351 and am wondering if i need to adjust it like they do on chevy's. my check engine light is on and it is saying something is wrong with my tps. thanks
Old Jun 11, 2010 | 09:41 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection Throttle Position Sensor (TPS) Info here.
Old Jun 11, 2010 | 09:43 AM
Conanski's Avatar
Conanski
The TPS should produce about 0.9v at the closed position and this is something that needs to be verified when it are replaced, simply bolting it on is no guarantee it will be set right.
Old Jun 11, 2010 | 09:44 AM
rla2005's Avatar
rla2005
In most cases if the voltage is between 0.6VDC and 1.0VDC with the throttle closed you will be good to go. There is very little "slop" in the mount holes and screws to try and adjust. If your new one is way out of whack it could be due to someone previously fiddling with the throttle stop screw.
Old Jun 11, 2010 | 10:05 AM
ymeski56's Avatar
ymeski56
Der Postmeister
There's two types, adjustable & non adjustable.
Old Jun 11, 2010 | 10:16 AM
danr1's Avatar
danr1
What test result is it? KOEO or CM?
If CM did you clear the old memory so the computer could relearn the new sensor?
Old Jun 11, 2010 | 10:45 AM
subford's Avatar
subford
After replacing a sensor always unhook the battery for 30 minutes.
After hooking the battery back up clear the memory code by grounding the STI wire and when the MIL starts to flash remove the ground from the STI wire and then drive it for 10 miles and recheck your codes.
njtinman2
Sep 11, 2014 08:22 AM
ungerp
6.7L Power Stroke Diesel
Dec 31, 2013 01:47 PM
1badshovel
Apr 17, 2011 06:01 PM
gearheadz80
Apr 18, 2006 04:53 PM
Iron Horseman
Mar 23, 2006 04:28 PM
