The first thing the AE checked was any codes, I usually check all the codes from all the sensors to see if anything can be a issue later on.
The report showed
U1262 SCP (J1850) Communication Bus Fault
C1284 Oil Pressure Switch Failure
P1812 4-Wheel Drive Mode Select Circuit Failure
I had cleared my codes from the P0470 this morning so right now only around 16 miles since reset, should I drive some more to see if some of the codes will clear them self.
If they don't reset themselves what would everyone's opinion on fixing these codes.
