look what i found!!!!
Old Dec 19, 2012 | 06:31 PM
  #31
HIO Silver's Avatar
HIO Silver
Originally Posted by BabyBlueHiboy
Thread is kinda old... But I currently attenda high school with a very advanced pipe bender. If someone could shoot me some measurements I could try this thing out. I'd really appreciate it .
You really need an actual push bar and front bumper (cause the 73-77 and 78/79 due to the slight differences) in hand to get it shadowed correctily.
BBH & Rich,
I've got measurements & angles.. enough to get it in the ballpark. 'got 'em from your pics Rich! Will post later.
Old Dec 19, 2012 | 09:02 PM
  #32
HIO Silver's Avatar
HIO Silver
Pic below....
Some notes (garnered from pics of measurements cuz I don't have one on hand!):
First, I would make the mounting plates and physically bolt them on.
Bends A1 and A2 have a 7-inch radius. Accounting for extra tubing for the bends back towards the bumper, mark the straight tube at 12.9 inches and 34.75 inches. I would mark the tube and bend those first... 82 degrees. If prototyping, I suggest leaving 12 inches of extra tubing so the measurements above would actually be at 24.9 inches and 46.75 inches. You can fine the actual length required later. Don't forget that the bending die needs to be able to hook onto the tube for the bottom bends.
Before removing the tube from the bender, measure the span at the lower tubes to ensure that they would locate outside of the lower bumper bolts.. about 37 inches.
Length 1 (5 in the photo is marked 15.5") should really be center line to center line, which is 18 inches. The top crossbar is 24 inches- again, center line to center line intersection with the image's right tube.
Now bend each lower return arm 90°. I cannot determine the radius but I figure 7 inches since the die is already in the bender. Cut and fit the returns so that the pushbar is 3 inches away from the bumper at is closest point. You'll have to sneak up on that cut cuz the bottom face of the bumper tapers down and away.
The lower crossbar is 30 inches at its longest measurement - the tip of each fishmouth. It is spaced 6 inches from the upper cross tube (OD to OD) or 7.875 inches center line to center line.
Good luck and let us know how it turns out. Measure twice, bend once!
Old Dec 20, 2012 | 12:23 AM
  #33
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Like I said having one actually there would be the best and have a bumper to test fit it to would even be better.
Yes let us all know what you get worked out, anxiously waiting.
Look at what I found with a OEM guard on it, I am working a deal to get just it, or maybe the whole truck??
Old Dec 20, 2012 | 08:59 AM
  #34
BabyBlueHiboy's Avatar
BabyBlueHiboy
Really wish I would've found this thread sooner, today is our last day before break. I'm gonna work my butt off to get as much done as I can. Thanks HIO for the measurements.
Old May 2, 2016 | 12:36 PM
  #35
jbehuniak's Avatar
jbehuniak
ZOMBIE THREAD!!!!! Look at the dates on the top left of each post... 2012
Old May 2, 2016 | 06:04 PM
  #36
akguy09's Avatar
akguy09
Originally Posted by Wendy Orr
Please if u want 2 sell that push bar please call or text 501-296-9956
Would you quit doing that to every push bar thread, its getting old already.
bigwin56f100
Oct 10, 2016 03:35 PM
tardster
May 30, 2010 08:30 PM
mred33
2004 - 2008 F150
16
Oct 16, 2008 09:24 PM
fordboy_52
Kansas Chapter
Apr 14, 2008 10:12 AM
jniolon
53
Oct 22, 2007 05:45 PM
