Sponsored by: Auxito
Power locks problem
Old Oct 16, 2012 | 03:25 PM
John90's Avatar
John90
Power locks problem
Hey,
when I want to unlock the doors on my drivers side switch the passenger door stays locked. At first it just unlocked slowly and now it's dead.
When I press unlock on the passenger side itself, both locks unlock just fine!
'98 4x4 ext. cab
Greets
Old Oct 16, 2012 | 06:52 PM
Bluegrass 7's Avatar
Bluegrass 7
You either have a bad switch or the lock motor is froze.
Remove the arm rest cover to get at the switch assembly for testing voltage at the termnals.
If ok, the door panel has to come off to access the lock motor.
The lock motor is actually a motor that turns a fast helex shaft to pull or push the lock up or down depending on the polarity of the voltage the switch applies.
The motor is mounted vertically and has a rubber boot to keep water out of the motor.
The boot comes apart from age and lets water in so rust takes over and seizes the movement.
Good luck.
Old Oct 16, 2012 | 09:46 PM
QuarryTruck's Avatar
QuarryTruck
^^^^^^^2nd that ^^^^
Old Oct 16, 2012 | 10:29 PM
Doc's Avatar
Doc
I can vote for the bad switch theory, but I am not sure about the possibility of a bad lock motor. If that was the case, the passenger switch wouldn't make a difference like he describes. Right?
If it's the driver's side switch, it will be a straightforward fix.
I've had a lot of problems like this over the years with my 97. I have concluded that the deterioration of grounds cause a lot of the problems with the door controls. For instance, I have had a very sluggish drivers side window for years. Sometimes it goes down. Other times it does not. Same with the passenger side window. I changed various motors, switches, and relays with no improvement. This past weekend, I had to tear out my dash to replace the heater core. Now both windows work much better than they have in years from either side's controls. The only thing I can figure is I somehow cleaned off the ground connections between the dash panel and the chassis by removing and reinstalling those mounting bolts. I know it sounds crazy, but my window switches barely worked at all last week (and sometimes they didn't). Now they work very well after that project.
Old Oct 16, 2012 | 10:42 PM
QuarryTruck
ah good point Doc
jenkinsj
Electrical Systems/Wiring
Mar 10, 2013 08:14 PM
kable
Aug 23, 2004 09:44 PM
missouguy
Dec 20, 2003 09:21 AM
jamyboy
Mar 5, 2003 07:42 PM
Crash55
Oct 16, 2002 02:59 PM
