Sponsored by: Real Truck
2006 E350 ABS sensor location
Old Oct 15, 2012 | 09:41 PM
MotorPool's Avatar
MotorPool
Post 2006 E350 ABS sensor location
Hello all... have a Dorman ABS/rear differential speed sensor... part number 970-012....where exactly is this sensor located? One place says it's on the rear brakes and the other says it's located in the rear differential... thanks
Old Oct 16, 2012 | 06:30 AM
redford's Avatar
redford
FTE Leadership Emeritus
On the pickups, the VSS (Vehicle Speed Sensor) is located on the top of the rear differential. I would imagine it would be the same for an E-350, if the same diff is used.
Old Oct 16, 2012 | 09:49 PM
MotorPool's Avatar
MotorPool
I'm not very familiar with Ford rear ends other than the 9 inch, 8.8, and Sterling 10.25... the rear end is a 10 bolt rear end but I didn't see any sensors on the rear end... anywhere else it could be located?
Old Oct 17, 2012 | 03:38 AM
Yahiko's Avatar
Yahiko
It should be on the inside top edge. Look for a
wiring harness. You should also see the vent
line running up to the frame. If you don't find it
let me know and I'll look in my magic Book (DVD)
at the location diagram.
I don't know if you can send a PM yet but give that a try
if you don't find it or post a note here and like I said I'll have a look/
Sean
Joe Bleaux
Oct 18, 2016 03:13 PM
aj88V
Feb 10, 2015 08:39 PM
mdpitt
1997 - 2003 F150
Oct 8, 2007 10:48 AM
davrober
Jun 1, 2007 03:58 PM
papadelogan
Feb 1, 2007 11:26 AM
